Identify this problem
Old Aug 31, 2003 | 11:13 AM
AllDreamsAreRed's Avatar
AllDreamsAreRed
Default Identify this problem
When I'm accelerating up a hill, my A/C will (which is on AUTO) will divert air to the lower half and cut off the top half. Yesterday I tried to "force" it to stay on the top half by putting the A/C on top vents only. Well, when I went up a hill, it sucked all the cold air out of it and was blowing warm, humid air. Is this normal? I have had this car for 7 months now and have not noticed this before. If this requires fixing, what do I do?
Also, my cruise control is out of whack. If I set it on 75, it will get to 75.....eventually. First it will slow down to, say, 63 before it kicks in. If it's a flat road it will stay on 75 for the most part but anything hilly will make it inaccurate, like it is drunk or something.
Are these 2 problems related? How do I get all this back on track?
Old Aug 31, 2003 | 11:21 AM
offershore's Avatar
offershore
Default Re: Identify this problem (AllDreamsAreRed)
sounds like a vacum leak.
Old Aug 31, 2003 | 11:31 AM
AllDreamsAreRed
Default Re: Identify this problem (offershore)
Vacuum leak? That won't vacuum my wallet to fix it will it?
Old Aug 31, 2003 | 12:28 PM
offershore's Avatar
offershore
No pop the hood look at all the lines see if one is off or dry rotted. check the vacuum can under the left front head light. does your cruise work?
Old Aug 31, 2003 | 12:52 PM
AllDreamsAreRed
Cruise works, just doesn't maintain a consistent speed.
Old Aug 31, 2003 | 03:34 PM
AllDreamsAreRed
I found it. I did a search and came upon a thread concerning the check valve under the passenger side fuel rail cover. It broke completely off when I took the fuel rail cover off, so now A/C works on lower half only and cruise doesn't work. I will get the part Tuesday from a local Chevy dealership since no auto part store in the area has the part. I'm sure glad I searched on here, I could've ended up paying a hefty hourly rate for a mechanic to find this.
Old Aug 31, 2003 | 10:07 PM
chief253's Avatar
chief253
I had the same problem. The check valve was under $6 at my local Chevy dealer. :)
To Identify this problem
