I have a set of shortie headers installed. On the passenger side of the motor there are 2 fuel lines that comes up beside the heater core box I think? Anyway, one of the header pipes comes close to the lines but is not touching the lines. Would it be a good idea to wrap aluminum foil around the part of the fuel lines that seem close to the header so as to deflect the heat? Or am I just going to bake it inside more by doing that? Or should I just leave it alone. Any suggestions would be appreciated. Thanks in advance :seeya
Re: [LT4] Headers too close to fuel lines (eamador11)
I was detailing my engine this weekend & noticed the same fuel lines (stock headers). There is supposed to be a plastic clamp that captures the fuel lines & pulls them away from the headers. Mine was broken & I used a couple of tie wraps to pull the lines away. Do you still have the black plastic piece or is it gone?
Re: [LT4] Headers too close to fuel lines (froggy47)
I'm running JBA shorties on my 92 and have the same problem. I wrapped both fuel lines with the heat tape. I also used several tie wraps to pull the lines GENTLY away from the headers. They have about 5/8" clearance now.
[QUOTE]There is supposed to be a plastic clamp that captures the fuel lines & pulls them away from the headers. Mine was broken & I used a couple of tie wraps to pull the lines away. Do you still have the black plastic piece or is it gone?[QUOTE]
ahh good point! no, I dont have any strap on there. they must have busted it off at the dealer or something. ill try the plastic ties tricjk and use heat wrap as previously mentioned.
