'87 blower motor
Old Aug 31, 2003 | 08:22 PM
junkvette's Avatar
junkvette
1st Gear
Default '87 blower motor
after 1.5 wasted hours going thru the absolutely useless wiring diagrams in the Haines manual .... can some one tell me the color codes for motor speed ?? i've got only high speed, and my resistor is fine ... need to check back to the switch wiring ...... mark smith :mad
Old Aug 31, 2003 | 11:06 PM
jfb's Avatar
jfb
Default Re: '87 blower motor (junkvette)
Both the heater motor speed switch and the resistors get 12v from the heater/ac control switch through a yellow wire. The speed switch shorts out between the yellow wire and successively through the tan, and blue wire for increasing speed. The orange wire is high speed and it goes to a relay coil that switches from the resistors directly to 12v for high fan speed. You should have very low resistance measurements from the yellow wire to the tan and light blue and then the dark blue wire. I suspect the resisors have an open circuit (broken resistance coil or bad connection).
