Code 36 Opti-Spark Ignition Timing (Resolution Pulse) '93 Lt1??
Old Sep 2, 2003 | 08:43 PM
lt1_corvette93's Avatar
lt1_corvette93
Default Code 36 Opti-Spark Ignition Timing (Resolution Pulse) '93 Lt1??
I have a code 36 High Resolution Spark Failure, according to my Mac Tools Scanner, on my '93 Lt1 Coupe. Just curious if anyone else has had this problem and what you did to solve it. (Opti-Spark Replacement, ECM, PROM, Plug Wires??). It runs rough and the #8 and #6 injectors are not pumping enough fuel into the cylinders on the right side. Thanks in advance.
:confused:
Old Sep 2, 2003 | 09:37 PM
bogus's Avatar
bogus
Default Re: Code 36 Opti-Spark Ignition Timing (Resolution Pulse) '93 Lt1?? (lt1_corvette93)
any code from the opti a bad thing... and the main cause, I THINK goes like this:
The opti's high voltage side carbon traces from water getting in... that causes misfires... the computer cannot correct...
That's my latest theory... I would love to hear from others if this makes sense!
Old Sep 3, 2003 | 12:55 AM
Goody's Avatar
Goody
Opti replacement required is my input. Internal Opti failure will trigger this one.
Old Sep 3, 2003 | 04:17 PM
John Row's Avatar
John Row
Get ready to replace the opti. I know a F-body guy that just took his old Opti apart cleaned it very well and replaced it for another 20K+ miles (and still going!), but he's lucky at cards too.
Unless you like to tinker and have the time, do it once and replace the whole thing. A low resolution fault is in the optics/electronics side.
Here's a pretty good description of an opti-spark: http://www.charm.net/~mchaney/optisprk/optisprk.htm
Old Sep 3, 2003 | 05:00 PM
Strick's Avatar
Strick
We all seem to agree that you are in for an Opti replacement. My advice is to go with a new OEM AC Delco Opti-spark, plug wires (MSD or Taylors), Plugs (NGKs or AC Delco Rapid fires or maybe Densons) and while you have the water pump off replace it. One thing, vent the opti-spark (see http://www.corvetteclinicinc.com C4 solutions). The other option would be to go with a Dyna-spark from Dyno- Tech (on the left column). You could also go with an electric water pump. See tools>tech tips>C4>meziere install. There is lots of info on this right here.
Old Sep 3, 2003 | 05:28 PM
Nathan Plemons's Avatar
Nathan Plemons
One option that nobody has mentioned here actually happened to me. The opti has a short pigtail that connects it to the rest of the car's wiring harness. Pull this connector and take a look at it. Make sure that all the connections look good. If they are corroded or damaged it can cause signal troubles.
I had this happen and replaced the opti before I figured it out. In my case I replaced a perfectly good opti because the connections had somehow corroded up inside this connector. It might not be the problem but it would certainly be easy to look at.
The only problem is that this little 2-3 foot pigtail costs something like $70
It's still better than $300 for an opti though.
Old Sep 3, 2003 | 07:03 PM
lt1_corvette93
Default Re: Code 36 Opti-Spark Ignition Timing (Nathan Plemons)
Thanks guys, for all the input. However, I got angry and parked the car for the winter. Curses to GM's opti-spark design! I'll deal with the opti replacement next spring. I'm sure I can find some aftermarket goodies, over the winter, to bolt on while I have everything apart also. Thanks Again,
Emery :chevy
Old Sep 3, 2003 | 10:20 PM
Strick's Avatar
Strick
Default Re: Code 36 Opti-Spark Ignition Timing (lt1_corvette93)
Man it is too early to park the Vette. Don't let this get between you and your Vette. Get after it. :thumbs:
To Code 36 Opti-Spark Ignition Timing (Resolution Pulse) '93 Lt1??
