car keeps stalling and won't start
Old Sep 3, 2003 | 09:22 PM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
Default car keeps stalling and won't start
Today when I was driving home, the car stalled on me. It wouldn't turn over for a couple of minutes and the started up. I went about a 1/4 mile and as soon as I came to idle it stalled again. This time it started right up. Went about another 1/4 mile and it stalled when i stopped in my driveway. I started it up in my driveway and it ran fine. I revved it a couple of times and let it back down to idle. I repeated this for a couple of minutes and it was fine. A couple hours later, I started it and it lasted about 5 seconds and stalled. Now it won't start at all.
I went to pull the codes (if any) and now the coolant fan comes on as soon as I put the ignition in the on position, this is without putting the wire in the two pin slots. With the wire in the ALDL, the SES light doesn't blink. :confused:
any suggestions?
I just replaced the fuel pump last year. the car is cranking, just not starting, so it's not the battery or alternator (which are new from last year also).
tia
Old Sep 3, 2003 | 09:26 PM
bogus's Avatar
bogus
Default Re: car keeps stalling and won't start (86_RedRider)
Idle Air Control?
Old Sep 3, 2003 | 09:28 PM
86_RedRider
Cruise-In V Veteran
Default Re: car keeps stalling and won't start (bogus)
sticking or just faulty? i just cleaned it out this past spring.
Old Sep 3, 2003 | 09:43 PM
bogus's Avatar
bogus
ick... donno... just throwing out the idea...
how about the throttle position sensor? they wear... and do need adjustment.
Old Sep 3, 2003 | 09:44 PM
86_RedRider
Cruise-In V Veteran
it could be i have no idea. i did a search and someone else had the same exact problem, but no solution in the post. i'm doing a little more searching on it.
http://forums.corvetteforum.com/zerothread?id=527936
Old Sep 3, 2003 | 10:09 PM
86_RedRider
Cruise-In V Veteran
could it be a faulty ecm?
Old Sep 3, 2003 | 10:56 PM
86_RedRider
Cruise-In V Veteran
i'm hearing a sparatic clicking near the fuel rails. clogged injector, bad FPR, etc?
Old Sep 3, 2003 | 11:18 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
:confused: Looking thru my C4 books.
Sorry, I'm trying! Give me soom time!
tony
[Modified by oldace84, 8:19 PM 9/3/2003]
Old Sep 3, 2003 | 11:28 PM
Goody's Avatar
Goody
Car is in LIMP Mode. I ended up replacing my ECM to cure this mess. I sent ya an IM stating the same thing. Try reseating the EPROM first as well, but my guess is the ECM finally went bad. I ordered mine from Superior for something like $140 or so after core refund. (Jeff was still there then).
Old Sep 3, 2003 | 11:40 PM
86_RedRider
Cruise-In V Veteran
Default Re: car keeps stalling and won't start (Goody)
fixed. bad electrical connection to the fuel injectors. the connection is right under the throttle body and has two connections in the plug. it must have rattled loose.
Thanks for everyone's help!
Old Sep 3, 2003 | 11:44 PM
scorp508's Avatar
scorp508
Hmm... what part of the fuel injector harness is under the TB?
Old Sep 4, 2003 | 12:08 AM
vader86's Avatar
vader86
Default Re: car keeps stalling and won't start (scorp508)
Mine stalled out on me this afternoon, i went to crank her after she's been sitting 25min, and she immediately shut down after it cranked.
I cranked it again and revved it a little, she ran fine.
But i'm also going to be replacing my injectors soon.
Old Sep 4, 2003 | 01:05 AM
loflyin's Avatar
loflyin
Default Re: car keeps stalling and won't start (vader86)
The injector wires that you mention - which fuel rail did they come off of? If the passenger side, where the two wires yellow and black? If so, that would be the temp sensor and would explain why the fan came on. If from the driver's side and wires were purple and tan(ish), that is the 9th injector delay switch (only used when it is cold for a few seconds). These are both essentially under the throttle body. I ask this because, like Scorp, I am unaware of fuel injector wires under the TB. Also, after you found the bad connection, what codes did you pull? (Even if no problem, you should get a code 12 to verify that self diagnosis is working). Not being a smart***, but I have had a similar problem and I am curious as to what you found.
Old Sep 4, 2003 | 07:24 AM
86_RedRider
Cruise-In V Veteran
Default Re: car keeps stalling and won't start (loflyin)
pulled no codes. the connection is still loose. it's the connection that's mounted to the thermostat bolt. there are some vacuum lines that are mounted under it, one runs to the TB and one runs under the plenum somewhere. is this the cooling fan relay?
Old Sep 4, 2003 | 12:26 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
No, EGR Solenoid.
Old Sep 4, 2003 | 04:40 PM
86_RedRider
Cruise-In V Veteran
Default Re: car keeps stalling and won't start (Ray Quayle)
Thanks, for all of your help. I called ecklers, they are going to overnight me the part $34 for the solenoid and $30 for S&H. I'm getting married tomorrow and I needed to get the car running by then. Wish me luck and I hope I don't stall on the way home from the reception.
Old Sep 4, 2003 | 05:24 PM
jennykayes84vette's Avatar
jennykayes84vette
:flag Good luck, With the car and the wedding.
To car keeps stalling and won't start
Old Sep 5, 2003 | 10:07 AM
Davidsvette85's Avatar
Davidsvette85
Yea good luck with both for sure. :boxing
Old Sep 5, 2003 | 01:05 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
You said you replaced the fuel pump last year. Mine went out after 7 months. Check the pressure at the rail before you rule this out.
Old Sep 5, 2003 | 07:16 PM
CarAteMyMoney's Avatar
CarAteMyMoney
i had a similar problem with my old '87 camaro 6 cylinder, turned out to be the distributor module .. when it would get hot, it would die on me
you can check it with a heat gun
good luck, i know how tempermental '86's can me! :cheers:
