car still won't start!
Old Sep 3, 2003 | 10:25 PM
JJ 86's Avatar
JJ 86
Default car still won't start!
Ok it must be some kind of short somewhere. All the car does is crank but doesn't start. I have good spark as well as fuel but still i get only a crank. But the weird thing is that i went out and unplugged the vaccum line to FPR and the thing started right up and ran great (except for a little hesitation). Turned it off then reconnected the vaccum line and it still started. WTF.. After i let it set for a while then it only cranks. Any ideas? are there any sensors that will cause this to happen?
Old Sep 3, 2003 | 10:52 PM
LaVidaLoca's Avatar
LaVidaLoca
Default Re: car still won't start! (JJ 86)
How's the fuel pressure at the rail?
Can you hear/feel the injectors clicking when you crank? You can make a test light out of a small 12v lamp and check the injector pulse from the ECM.
If you have spark and think it's in time then focus on the fuel system.
Old Sep 3, 2003 | 10:55 PM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
Default Re: car still won't start! (LaVidaLoca)
i'm having the same problem. not to hijack your post, but i here a sparatic clicking near the fuel rails, when the ignition is in the on position. what does this mean?
JJ, is your fan running when it is in the on position? mine is and i can't pull codes.
Old Sep 3, 2003 | 10:57 PM
jfb's Avatar
jfb
You can't fool the laws of Physics. When it won't start, your engine isn't getting some combination of spark, fuel , air. Put a fuel pressure gauge on the shrader valve on the fuel rail and see what it reads when it won't start. With no vacuum line on the FPR, fuel pressure is maximum, maybe the FPR is defective and shuts off the fuel with a vacuum after it sits overnight. The fuel pressure gauge will show this.
Old Sep 3, 2003 | 11:03 PM
scorp508's Avatar
scorp508
Default Re: car still won't start! (jfb)
Have the plug wires been off recently? If so did it run after they went back off? Wondering if they are all off by one position on the cap.
To car still won't start!
