Cheap eprom burner
Sep 4, 2003 | 01:45 PM
Cheap eprom burner
If you are looking to pick up a burner try one of these.. I am using one now and it works great cheaper than the pocket programmer as well only $79.00
http://www.futurlec.com/EPROMProg.shtml
Sep 4, 2003 | 01:52 PM
Re: Cheap eprom burner (gregfloyd)
Sep 4, 2003 | 02:04 PM
This is the ALDL interface I use... Works great with DataMaster And Craig Moates software... I have mine permanently installed in my car.... Double sided sticky tape mounted to underside of ALDL connector... wires splice with piercer(vampire types) type connectors to ALDL wiring
http://www.makinterface.com/index_e.php3 $52.92
[Modified by gregfloyd, 7:05 PM 9/4/2003]
Sep 4, 2003 | 02:12 PM
what does the software work on? there is no mention of it in the link
Sep 4, 2003 | 02:43 PM
Re: Cheap eprom burner (-=Jeff=-)
I have used the Eprom burning software on both windows 2k and Windows XP
don't know about 98 or 95 but i bet it would
Sep 4, 2003 | 10:13 PM
Also does it do 29series (EEPROM) chips as well?
Sep 5, 2003 | 02:43 PM
I have never tried.... I think it is mainly a 27 series type of unit though
Sep 5, 2003 | 04:35 PM
Thanks,
I guess I will have to order the Pocket Programmer 2
Sep 8, 2003 | 08:01 PM
What software are you using with this?
Is it windows based? I am not familiar with the process but I am considering purchasing one of these and experimenting.
I would appreciate any tips that you offer.
Thanks,
John
Sep 14, 2003 | 10:54 PM
:withstupid:
Man... if it did/does work on the 29-series... I think it would be the ultimate setup! I think I will call them and ask; heck you never know I guess.
Greg: Any chance of you posting or emailing me a photo of your ALDL in-car setup? I'd like to see just how you managed it, if it's not too much trouble.
:cheers:
[Modified by Ramanstud, 11:01 PM 9/14/2003]
Sep 15, 2003 | 03:14 PM
Re: Cheap eprom burner (Ramanstud)
Ill take some pics and post em....
I picked up some flash / 29c256 chips this weekend.. and this unit does work with them
Sep 15, 2003 | 03:18 PM
I just bought it and installed in on XP. I just need somone to tell me where to plug the PROM in the programmer b/c it has 3 different settings, and once i open the software for the programmer what do i do??
Sep 15, 2003 | 03:33 PM
:party:
Now does this mean you can over-write the 29C256s by just re-programming them, or have you only burned blank chips so far? Even still, great news!
:seeya
Sep 15, 2003 | 04:14 PM
I was able to reprogram them as well
Sep 15, 2003 | 04:16 PM
Re: Cheap eprom burner (Fast_vette89)
always start from the bottom of the zif socket........ with notch on chip facing up
Sep 15, 2003 | 04:51 PM
Which notch are you talking about? Will the chip hang down or up basically?
Sep 15, 2003 | 06:43 PM
Click for full size. See the notch on the left? That chip also has a white arrow for locating the #1 pin.
Sep 15, 2003 | 07:57 PM
Re: Cheap eprom burner (scorp508)
Sep 15, 2003 | 08:00 PM
Here is my aldl connector mounted in my car
eek i need to clean my carpet hehehe
Sep 15, 2003 | 09:26 PM
Greg,
Fantastic thread. Thanks for "giving a little back to the community" on this one! :jester
:thumbs:
