Have a check engine light, but can't get the code?
Old Sep 4, 2003 | 02:55 PM
Red91Vette's Avatar
Red91Vette
Default Have a check engine light, but can't get the code?
Recently my car has been running rough, it has a rough idle and after accelerating and you let of the gas and just cruise, the rpms go up and down. It can't hold a steedy rpm when not on the gas. I get a check engine light if I drive it for more then 30 mins, but when I go to use the OTC scan tool, it doesn't read a connection? It says make sure the key is on, which it is, so it has to be a bad connection somewhere? I have a pathfinder 94 chip in, so that works fine. I don't understand why it cant read the computer and find the code? I am fed up with this car and its deffinitly time to sell it, I just need to get it running right first! Thanks for any help guy guys can offer. :banghead:
Old Sep 23, 2003 | 09:21 PM
gbody5's Avatar
gbody5
Default Re: Have a check engine light, but can't get the code? (Red91Vette)
Possibly a bad ECM? When mine went south it caused the erratic idle and eventually I could not get it to go into diagnostic mode to pull the codes.
