headlight motor gears
Old Sep 4, 2003 | 04:12 PM
bigbert's Avatar
bigbert
Cruising
Default headlight motor gears
Does anyone know how to remove the black headlight motor gear from the case? It has a shaft that goes through it with ***** at each end, preventing me from sliding the gear off of the shaft.
Old Sep 4, 2003 | 04:35 PM
QuikZilver's Avatar
QuikZilver
Default Re: headlight motor gears (bigbert)
You shouldn't need to replace the worm gear. If that needs to be replaced, you are looking at a new motor. the gear that is replaced is the one that rides on the worm gear. There are 3 bolts that hold a cover over it. I need to yank both of mine out of my 93 and rebuild them. Driver side doesn't even come up anymore. I have teflon coated brass gears to replace the plastic gears and delrin bushings to go it. I had my gears teflon coated by a friend. If anyone needs to get this done, his web address is http://www.combatcoat.com. :cheers:
Old Sep 4, 2003 | 05:42 PM
Black'69's Avatar
Black'69
Default Re: headlight motor gears (Whitvette)
:iagree: Just replaced my bushings, works like a champ. Here's a C.F tech article on it. https://www.corvetteforum.com/techti...=156&TopicID=2
To headlight motor gears
