Headlamp problem on 94 vette
Old Sep 4, 2003 | 04:33 PM
adeak1's Avatar
adeak1
Default Headlamp problem on 94 vette
Dear All
The right headlamp will move up and down but when it retracts it will contune to run the motor for a few seconds. The left works fine.
Is it he gear??
Any Ideal's :confused:
Old Sep 4, 2003 | 04:36 PM
QuikZilver's Avatar
QuikZilver
Default Re: Headlamp problem on 94 vette (adeak1)
Bushings may be going out on it. That is how it started on mine. I need to rebuild both of mine. :D
Old Sep 4, 2003 | 06:01 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
Default Re: Headlamp problem on 94 vette (Whitvette)
:iagree: Replace the headlight bushings. 3 on each light. Order the kit from http://www.ecklers.com or http://www.madvet.com. Each kit will repair 1 light. They are around $5 each. Easy fix -- takes about 2 hours. Mine did the same thing and now works like new :thumbs: :seeya
Old Sep 4, 2003 | 06:06 PM
adeak1's Avatar
adeak1
All
Andrew :D
Old Sep 4, 2003 | 06:54 PM
Black'69's Avatar
Black'69
Here's a CF tech article on it. I just did it. Took about 2 hours, not hard just a little time consuming.
https://www.corvetteforum.com/techti...=156&TopicID=2
To Headlamp problem on 94 vette
