These injectors "tick" significantly louder than my stock injectors did. Anybody else have Holley injectors? Do they normally have a noticable tick? The idle is smoothed out and the car drives fine so I dont think there is anything wrong with the injectors, just curious.
No, not hard. Just got to remember to clean all the crap that collects on the manifold around the injectors before removing them. This way all that crap doesnt fall into the injector bungs when you do remove them.
Changed them because I had a problem with the fuel system not holding pressure once the engine was turned off. Had previously ruled out the FPR and pump, but it is still dropping so those are next to go.
