will an 85 ecm handle these mods??
Old Sep 7, 2003 | 10:30 AM
FNG's Avatar
FNG
Default will an 85 ecm handle these mods??
hi all. saved enough of my pennies to do a few minor mods. planning on long tube headers ( tpis or hookers, will do a search and see which ones are the least amount of hassle). an accel base manifold, port my stock runners and plenum. may be able to squeeze the piggy bank enough for some 1.6 roller rockers. dont have the bux for a sr. maybe later.
couple of questions: will the stock throttle body be enough?? and most importantly, will my 85 ecm be able to handle this stuff?? will i lose much low end torque??
thanks for any input here guys. not looking for a race car, just want a little better response and a few ponies. thanks again, regards, fng
oh , its a 4+3 if that make a difference
Old Sep 7, 2003 | 10:33 AM
Corvette0096's Avatar
Corvette0096
Default Re: will an 85 ecm handle these mods?? (FNG)
It will work fine..I have a 85 ECM in mine and no problems..You might have to change the chip at a later date, when you do a cam and head upgrade..
Old Sep 7, 2003 | 11:30 AM
FNG's Avatar
FNG
Default Re: will an 85 ecm handle these mods?? (Corvette0096)
thank you sir. was kinda worried it may not do the job. have read where you have to read these ecm's with a sundial. dont have any plans at the moment for a cam change. at 56 my reactions arent what they were :D and this thing will go sideways in 1st and 2nd as it is. just looking for a nicely tuned and breathing unit. thanks again, regards, fng
Old Sep 7, 2003 | 11:51 AM
Corvette0096
Oh one more thing, Your throttle body is pefect for your set up. GM hit it on the head of the nail with that one.
Old Sep 7, 2003 | 12:12 PM
MrNuke's Avatar
MrNuke
The stock ecm will work fine for any mods. Just get a new chip once you add the headers, or an AFPR to offset the lean-ness.
Old Sep 7, 2003 | 07:07 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: will an 85 ecm handle these mods?? (MrNuke)
my 85 ecm is still ticking i think its a timex :D :cheers:
To will an 85 ecm handle these mods??
