KYB's
Old Sep 8, 2003 | 09:06 AM
86shark's Avatar
86shark
Default KYB's
People that have put KYB's on their vette, I need to pick your brain!
Please respond.
Thanks.
Old Sep 8, 2003 | 09:24 AM
Corvette0096's Avatar
Corvette0096
Default Re: KYB's (86shark)
I just installed a set on my car and love them. Very firm shock.. $120 for all fours you can't bet it..
Old Sep 8, 2003 | 09:25 AM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
I put some on my 85 about 4-5 years ago. They were a nice affordable shock that worked well.
Old Sep 8, 2003 | 09:40 AM
86shark's Avatar
86shark
Default Re: KYB's (Corvette0096)
1 Did your fronts come strapped with the nylon strapping, my backs did
2 I had some rust stains at the bottom
3 did you use the rubber bushings that came with the fronts or did you use the old ones from the Bilsteins?
Mine don't seem to be good, car bounces a lot and makes noise like they are loose. even when I jack it up.
Old Sep 8, 2003 | 11:08 AM
Corvette0096
1=No.
2= No rust stains on mine.
3= Used the new ones that came with the shock.
I would send that set back and get a new set..
Old Sep 8, 2003 | 11:25 AM
86shark's Avatar
86shark
I am sending them back, and the new ones will be here wednesday. Thanks for the response. The reason I asked about the new rubber bushings is the old ones seem to be sort of pressed in and the opening on the shock mount is larger than the bushings.
To KYB's
