TPI oil cooler
Old Sep 8, 2003 | 12:59 PM
larryfs's Avatar
larryfs
Default TPI oil cooler
did the TPI motor have an oil cooler?
if so, where?
oil to coolant, or oil to air???
thx
Larry
Old Sep 8, 2003 | 01:21 PM
severe-1's Avatar
severe-1
Default Re: TPI oil cooler (larryfs)
The oil cooler was an option.
If you have it, there will be a coolant line running under your oil pan to your oil filter mount.
Old Sep 8, 2003 | 01:31 PM
LD85's Avatar
LD85
Default Re: TPI oil cooler (severe-1)
I tested my car this summer with and without, it drops the oil temp 10 degrees.
To TPI oil cooler
