Small mod horsepower gains?
Old Sep 8, 2003 | 06:17 PM
95_6spdvette's Avatar
95_6spdvette
Default Small mod horsepower gains?
Hi i was wanting to do some cheap mods and was wondering if anyone new how much these would gain Horsepower or Torque on an other wise stock car with the throttle body bypass kit. Appreciate the help!
Open Air lid
K&N or TPIS air filter
De-screened MAF sensor
Thottle Body air-foil
Muffler Eliminators
Old Sep 8, 2003 | 06:21 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Small mod horsepower gains? (95_6spdvette)
I've done the K&N, open lid and muffler eliminators. There is no gain in power, actually there is a small loss with the muff elims.
The sound from cutting teh mufflers off was well worth the small loss. My ET's did get better(only by .09), but I think that's mostly due to track and weather conditions.
Old Sep 8, 2003 | 07:18 PM
Nathan Plemons's Avatar
Nathan Plemons
You're probably looking at about 5 to the wheels out of all of that. I've dyno'd a stock car with a closed air lid and paper filter vs my open lid with K&N. I don't remember exactly but it was less than a 5 horsepower gain from that. Now my car suffered a pretty good loss using his paper and closed lid. So it goes to show that it does some good, just not on a stocker.
The MAF is an interesting topic for debate that I just stay out of. I don't have a MAF and I don't want one.
The Air Foil was dyno proven useless on national T.V. not very long ago so I wouldn't waste the money there either. Removing the mufflers will certainly give you more sound pleasure, even if they don't give you any power. It's probably a wash on them, anything it gains you in top in power you'll probably give up in low end grunt.
Old Sep 8, 2003 | 11:21 PM
95_6spdvette
Default Re: Small mod horsepower gains? (Nathan Plemons)
Thanks for the info, didnt know if all those combined would help out on each of theres performance. Think if i got some 1.6 ratio roller rockers those mods would show a little extra performance than they would on a stock engine? Was curious on if i should invest in the rockers with new guide plates and harder pushrods!
Old Sep 8, 2003 | 11:45 PM
BAM92's Avatar
BAM92
I would use a K&N filter with a cut airlid and invest in a good cat back exhaust. One member dynoed his corsa for a 17 rwhp gain alone. If anything it will gain some hp but with added sound be alot more fun to drive. Then go on from there when you feel the need for another hp injection.
Old Sep 9, 2003 | 12:26 AM
hngacurv's Avatar
hngacurv
Default Re: Small mod horsepower gains? (BAM92)
Here is a link for the descreened MAF showing 4.2HP gain http://forums.corvetteforum.com/zerothread?id=646170
and here is a link showing a 6TQ from a TB coolant bypass http://forums.corvetteforum.com/zerothread?id=530749
Old Sep 9, 2003 | 07:08 AM
Nathan Plemons
Default Re: Small mod horsepower gains? (hngacurv)
That link to a descreened MAF is on a TPI car. It's a completely different MAF so it may or may not have the same effect.
The 1.6 rockers alone will probably give you about 10. Most mods do compliment each other but I still woulddn't ask for much. My friend that I let borrow my K&N with open lid actually had 1.6 rockers at the time, his only real mod.
Old Sep 9, 2003 | 07:45 AM
Dark-Knight's Avatar
Dark-Knight
:yesnod: Yep, what Mojo says. :yesnod:
To Small mod horsepower gains?
