Jumping Idle Speed
Old Sep 8, 2003 | 09:54 PM
Dan94's Avatar
Dan94
Default Jumping Idle Speed
My 94 LT1 has just developed an intermittant problem. The engine will be idling normally at 600-700 and all of a sudden it jumps to about 1200 RPM. About a second later, it returns to normal. This can be quite surprising when you're in gear at a set of lights and the car wants to jump ahead. Doesn't happen often, maybe more when the car is cold. Ideas? Thanks in advance any any guidance.
[Modified by Dan94, 4:57 AM 9/9/2003]
Old Sep 9, 2003 | 06:00 AM
Dan94's Avatar
Dan94
Default Re: Jumping Idle Speed (Dan94)
Could the cruise control be causing this?
Old Sep 9, 2003 | 09:15 AM
ittlfly's Avatar
ittlfly
My first thought is a bad TPS. .....Or worn bushings on the butterfly plate in the throttle body. A problem with either will cause a burst from the injectors as the ECM thinks there is a demand for fuel.
[Modified by ittlfly, 6:16 AM 9/9/2003]
Old Sep 20, 2003 | 03:05 PM
Frank92's Avatar
Frank92
Default Re: Jumping Idle Speed (ittlfly)
i have no solution but the same problem. 92 auto. i replaced the iac but nothing. i was thinking about a vaccum leak. or could it be something with the auto trans ?
i hope for some real experts here .
frank :confused:
Old Sep 20, 2003 | 04:03 PM
ittlfly's Avatar
ittlfly
Default Re: Jumping Idle Speed (Frank92)
You also might check you resistance of the injectors. They should be within 1 ohm of each other. It's possible that they could be shorting out. I'd also do a injector balance test. Just a thought.
Old Sep 20, 2003 | 06:07 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Replace your TPS. About 15 bux.
If still not fixed, remove the IAC and clean it. Don't forget to clean up in there where the pintle fits in the throttle body.
You can replace the IAC for about 60 buks.
That should do it.
Old Sep 20, 2003 | 06:31 PM
Dilligas's Avatar
Dilligas
Default Re: Jumping Idle Speed (VetNutJim)
My 94 did the same thing, it was the optispark. I replaced it and no more problems.
Old Sep 23, 2003 | 05:57 AM
Dan94's Avatar
Dan94
Problem solved. Large vacuum hose near TPS somehow had come loose. Put it back on and idle normal.
To Jumping Idle Speed
