Fuel Pressure drop??
Old Sep 9, 2003 | 06:00 AM
Gregory VanLare's Avatar
Gregory VanLare
Default Fuel Pressure drop??
My 85 runs okay under easy driving conditions but when I put my foot down hard it will hesitate a little (sometimes) and with a fuel pressure gauge on, the pressure will drop! It doesn't impact on the idle just under load. I've also noticed when I step on it going around a corner to the left, the same thing happens, hesitation! I thought this might be the fuel pump and my mechanic said the pump wouldn't go gradually. He thought it might be the AFPR or a vacuum lead leading to the fuel pressure regulator?? I don't want to replace the fuel pump if that's not the problem. Any suggestions?? Oh, I have a Holley AFPR with is only two years old so I doubt that it leaking. Thanks. :confused:
Old Sep 9, 2003 | 02:13 PM
LaVidaLoca's Avatar
LaVidaLoca
Default Re: Fuel Pressure drop?? (Gregory VanLare)
Fuel filter OK????
Old Sep 9, 2003 | 02:40 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Check fuel pressure at idle with the vacuum line connected and with it plugged to assure it's behaving properly with no vacuum leaks.
If not done recently, change the fuel filter.
Before replacing the fuel pump, pull it and clean the three electrical contacts just under the mounting flange. These copper contacts become oxidized over time and can cause fuel delibery problems.
Old Sep 9, 2003 | 05:51 PM
6spd's Avatar
6spd
Default Re: Fuel Pressure drop?? (65Z01)
also some vettes do that when they have low fuel in the tank it happened to my friend
Old Sep 9, 2003 | 07:06 PM
FostersPerformance's Avatar
FostersPerformance
Default Re: Fuel Pressure drop?? (6spd)
I can help if i know if its an l98 or tbi....
Old Sep 9, 2003 | 11:00 PM
Gregory VanLare
I just changed my fuel filter and my 85 is a TPI. I'll check the connections although I doubt they are oxidized, I had a leak and the garage said that the gaskets were crinkled and caused the leak when the pump pressurized.
[Modified by Gregory VanLare, 11:01 PM 9/9/2003]
Old Sep 9, 2003 | 11:15 PM
FostersPerformance
You can just unplug the vac line to the regulator and make sure to plug off the vac line as well..This will bring the pressure up a few (2-3)pounds,which should be benifical to you..
I work on nothing but FI systems, believe me, pumps DO go gradualy(spelling?)...They are usually very noisy when they are on there way out..Listen for a high pitched whine..
But if you pressure drops off like that , then yeah, id be looking at the pump if the regulator unplugged dosent help.
What does the pressure drop to, and at what rpm does it happen???How long does it hesitae and how bad??? Backfires or popping?? Give me as much as you can on just how bad it stumbles..
But it does sound like the fuel pump..
Brian
To Fuel Pressure drop??
