Turbo V's SC
Stock 88.
I was reading the procharge website and it said that the D-1 could pull 32PSI does this mean i can hook it up at 15PSI oF boost and get alot of power with no lag?
I leading 2wards the sc cuz i love them they r very :cool:.
I also have any idea for a PROJECT car, R_33 Skyline (possably GTR) with 406 SB TT :smash: :smash: , show those *** boys wat they r missing hehehe :jester
But SC IMHO is nice because i still have a lot of torque and hp it makes is really nice and just like turbo's running around town in cruise mode you are running jsut the engine :D
So SC seems to be the hot thing now but i am sure when some one fabs up a kit that is a easy install for a turbo that will be the hot thing!
Also when you go procharger if you do even the instructions suck and an average joe can install it with bad instructions it is that easy! Imagine if the instructions were very clear and understand able! :D
I get 700 hp out of a little v6 buick with a single turbo. over 1k hp is a walk in the park with a fully built twin turbo small block.
go look at the big boys running pro street sometimes. the twin and single turbo cars run 1400 hp and up and have decent reliability.
if you have doubts, that alone will tell you that the supercharger kits are the way to go. :D
"I was reading the procharge website and it said that the D-1 could pull 32PSI does this mean i can hook it up at 15PSI oF boost and get alot of power with no lag?"
No, running 15# of boost will require alot of supporting hardware, and a good tune and programing. 32 psi represents the max boost that the blower can make on what ever engine setup they wrere using mathmatically. Just because they say there charger is capable of 32#'s of boost on a stock LT1 dosent mean they have actually done it. Just shows you what it is capable of.
Kinda having a hard time saying what i mean.
Turbos are the ultamit imho, If your into wrenching. Instalation Is alot more difficult and can be a little more tricky to tune. Turbo lag is a thing of the past. A proper turbo setup for the street will have virtually no lag. There will always be some, but thats just the nature of the beast.
Ive heard good thing and bad things about procharger, do some reasearch on other sites and youll see what i mean. Theres no question there systems can make alot of power though.
Go with a sc if your just startingout and not into fabrication. Go with a turbo if you really want somthing exotic and dont mind the extra work.
Hope this helps a little,
:cheers:
and this was at only a fraction of the 40psi this tv-6 (the turbo) can make.
these engines are way cool, 1000 hp is enough turbo or blower!!!
my zr1 has 600 hp and it's kinda enough even at the level of power
anything much over 500 rwhp gets pretty tough to hook up on the street. :party:
http://www.my-wrx.com/wrx/pics/turbovette/index.php
