Injectors from 85 into 87?
Old Sep 9, 2003 | 10:30 AM
Topless87's Avatar
Topless87
Default Injectors from 85 into 87?
I've heard that 85 injectors are 24# but my 87 has 22#. If this is wrong, just say so and ignore the rest.
I'm doing a mild rebuild on my 85. Barely over stock specs. But, I have big plans for my 87. Should I swap injectors? The 85s were just reconditioned by TPIS too! Chips aren't a problem, I can burn new ones with the correct constant. Does this make sense? What do you think? :smash:
Old Sep 9, 2003 | 10:31 AM
scorp508's Avatar
scorp508
Default Re: Injectors from 85 into 87? (Topless87)
Sure toss em' in if you'd like.
Old Sep 9, 2003 | 10:39 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
?-are stock 87 injectors #22? - also - if you put in #24 do you need to do any chip mod?
Old Sep 9, 2003 | 10:59 AM
vader86's Avatar
vader86
You can if you want.
No chips strictly necessary for just a injector change, but you do want an AFPR if you cant burn a chip.
To Injectors from 85 into 87?
