Clutch problems help!
Old Sep 9, 2003 | 03:28 PM
Storz's Avatar
Storz
Default Clutch problems help!
Car has been driving fine, but today when I went to run up to the store, second stop out of my drive way, about 30 yards, I push in the clutch and there is a little 'pop' noise/feeling and the clutch got really soft and then 75% of the way thru the pedal stroke there is a hard spot, engagment is pretty much right off the floor, I havent driven it enough to know if its slipping or not since it happened, but I drove about 50 mile on sunday and it was fine. Any ideas?? I would like to know before I start ordering a clutch kit :sad:
[Modified by Storz, 8:29 PM 9/9/2003]
Old Sep 9, 2003 | 04:28 PM
T1Kilr's Avatar
T1Kilr
Default Re: Clutch problems help! (Storz)
Ryan,
1st... whats the fluid level?
2nd.. can you remove the dust shield and get a look inside?
my first guess is that maybe the clutch fork or pivot is on its way out.
Old Sep 9, 2003 | 04:31 PM
Storz's Avatar
Storz
Default Re: Clutch problems help! (T1Kilr)
level is good
removed dust seal and its right where it should be
its nasty and black so a fluid change is the first thing I am gonna try
To Clutch problems help!
