Replacing the evaperator
Old Sep 10, 2003 | 04:07 AM
93 ragtop's Avatar
93 ragtop
Default Replacing the evaperator
Has anyone done this? I was wondering how hard it was to remove it.
Old Sep 10, 2003 | 05:50 AM
96Silver_Conv's Avatar
96Silver_Conv
Default Re: Replacing the evaperator (93 ragtop)
can i ask why do you want to remove evap.?? it's a big job!! :eek:
Old Sep 10, 2003 | 07:30 AM
93 ragtop's Avatar
93 ragtop
Default Re: Replacing the evaperator (96Silver_Conv)
Well im a little embarrased to tell, but while doing some work on the engine, the suction line going to it was lifted a little to high and broke loose in the evaperator. The charging part, vacuuming etc, I am not worried about, just how hard is it to get the evaperator out?
Old Sep 10, 2003 | 01:27 PM
SunCr's Avatar
SunCr
No need to be embarassed. I once jacked up my home unit to build a deck underneath it and snapped the main line. Fortunately, insurance covered it. You need to remove everything next to the housing or anything blocking it. When I had my heads off, I marveled at how easy it would be to get at, but you don't need to go that far. Generally, the right wheel and lower well need to come off and removing the fender helps. Jacking the right side up will make it easier to crawl underneath so that you can access the lower bolts. The blower motor needs to come off and then take it apart and remove it in sections - the half closest to the fender first. Be sure to seal the halves and where it meets the firewall; otherwise, water will get in and find it's way into the passenger compartment as the weep hole is only large enough for normal condensation.
Old Sep 10, 2003 | 06:23 PM
93 ragtop's Avatar
93 ragtop
Default Re: Replacing the evaperator (SunCr)
Suncr,
Thanks for the response. If it was my home unit Id be a lot happier. I do that for a living. :D HVAC contractor. Anymore I dread doing about anything to this car. Everything seems so hard to get at.
Old Sep 10, 2003 | 11:49 PM
BlackbirdZ07's Avatar
BlackbirdZ07
I had to replace mine because I damaged it when replacing one of the AC hoses. It wasn't that bad a job. As said above, remove the lower fender and the wheelwell panels, windshield washer reservoir, etc. The nuts that hold on the cover at the bottom are accessed from under the car. If you're thinking of replacing spark plugs, this is the time to do it because the dreaded rear passenger side plug is easily accessible.
One particular word of caution: be very careful when removing the cover not to damage the heater core! I manhandled the parts to get them out, and I ended up breaking the solder joint on one of the heater core pipes. As a result, the heater core leaked, and I had to replace it, which was a much bigger job than the AC evaporator core. So in replacing the AC hose I damaged the evaporator core, and in replacing the evaporator core I damaged the heater core. Talk about a lot of work to replace that AC hose! Be careful.
Old Sep 11, 2003 | 03:31 AM
93 ragtop's Avatar
93 ragtop
Default Re: Replacing the evaperator (BlackbirdZ07)
Sounds like my luck!! I did this trying to replace one of the radiator fan motors. Got in a hurry and lifted the accumulator to high. I learned one thing, alumium lines dont flex as well as copper. :cry. And as far as replacing the sparkplugs, I just did that and wires about 500 miles ago. Thanks for your advise and I will try to be careful.
To Replacing the evaperator
