leakdown test.
Old Sep 10, 2003 | 02:28 PM
devilfish's Avatar
devilfish
Default leakdown test.
..im going to rent a leakdown tester this weekend.
So whats the procedure??
Old Sep 10, 2003 | 02:41 PM
bogus's Avatar
bogus
Default Re: leakdown test. (devilfish)
lemme see if I remember. the specs should be in the helms manual...
however, the basics. you pump it up to a specific level, and then watch the other gauge as it drops (there are 2 gauges, one that shows how much you pumped in, the other to show how much is lost).
the numbers are then referred back to a chart of somekind to indicate whether there is a problem or not.
Old Sep 10, 2003 | 03:19 PM
devilfish's Avatar
devilfish
Default Re: leakdown test. (bogus)
so i guess its importand to have both the valves closed for that cylinder?
Old Sep 13, 2003 | 07:18 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Professionally done, how much $$$$$$$$$$$$.
Like to know. This is a good test.
tony
To leakdown test.
