Name That Sound - Video Inside
Old Sep 11, 2003 | 01:27 AM
Tin Man's Avatar
Tin Man
Default Name That Sound - Video Inside
So a while back my dad swears he's hearing this cracking noise, I listen to it and you can distinctly hear it coming from the back left. Not only that, but you can sometimes see the wheel move a little when you go back and forth. In the video you can hear the transmission shift, then when it pulls in either direction you hear a *crack/crunch/pop* kind of sound, I swear its like a U-Joint.
http://webpages.acs.ttu.edu/nschrein...te-problem.MPG
I took it up to my work to get it checked out and they believe its a U-joint as well, but thats a pretty expensive guess. Also when you shift easy from 1-2 it shakes sideways for a couple seconds, anything to do with it? What do you think about it?
Old Sep 11, 2003 | 05:33 AM
jtfrog's Avatar
jtfrog
Default Re: Name That Sound - Video Inside (Tin Man)
MIne was doing that and i ended up replacing the hub assembly. The ujoint will be next
Old Sep 11, 2003 | 11:53 AM
Tin Man's Avatar
Tin Man
Default Re: Name That Sound - Video Inside (jtfrog)
You did the hub assembly and it fixed it?
Old Sep 11, 2003 | 01:10 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Try the 12 & 6 o'clock check to make sure your wheel bearing are OK. If those check my guess would be a bad u-joint.
Old Sep 11, 2003 | 06:43 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
I am 95% sure it is the outer u-joint. Had a buddies do the exact same thing and the 1.5 hour swap of the u-joint fixed it up. His sounded so bad I thought is was the hub at first.
Old Sep 11, 2003 | 07:15 PM
Tin Man's Avatar
Tin Man
Default Re: Name That Sound - Video Inside (Vette92)
How much did it cost?
Old Sep 11, 2003 | 07:18 PM
LD85's Avatar
LD85
U joints cost $20 each times 2 and takes a couple of hours to swap out.
Do a search and you will find part #'s.
Old Sep 11, 2003 | 08:04 PM
screamingeagle's Avatar
screamingeagle
definately the u-joints, mine was doing the same thing. Only makes the noise on acceleration, forward and backward, but fine at idle. If the rear end seems a little loose probably a good idea to replace both of 'em ASAP but the price on parts is right, just a time consuming operation :iagree:
Old Sep 12, 2003 | 02:56 AM
nxs055's Avatar
nxs055
Cruising
does it feel like the rear tires are out of balance? (you know, a shake when you get up some speed)
if so, then you may check into the air pressure sensor inside the tire...
the band on my passenger side rear broke and the stuff was just bouncing around in there... It made some pretty strange noises... I thought for sure that something was seriously broken... but when we took the tire off and rolled it, you could hear the stuff rollin around inside.... check that first... its the easiest....
Old Sep 12, 2003 | 11:44 AM
Tin Man's Avatar
Tin Man
Default Re: Name That Sound - Video Inside (nxs055)
Rad.
Old Sep 12, 2003 | 11:56 AM
1986CE's Avatar
1986CE
yup...sounds exactly like mine as you desribed. was the outer u-joint. Very easy, jack it up and grab the half shaft and move it front and back and see how the wheel follows your movements.
To Name That Sound - Video Inside
