1995 vette with hypertech programer
Old Sep 12, 2003 | 05:48 PM
arcticvette's Avatar
arcticvette
4th Gear
Default 1995 vette with hypertech programer
I am new to the forum, I have a 95 vette and used the hypertech reprogramer. I didn't do the programing myself I had a mechanic buddy of mine do it. I have problems with it shifting sometimes. Just wondering if anybody else has used the hypertech reprogramer? I haven't read anything on the forums about them. :troll
Old Sep 12, 2003 | 07:09 PM
TheStef's Avatar
TheStef
Default Re: 1995 vette with hypertech programer (arcticvette)
Only thing I know is that I would only have my car reprogramed if I made major internal changes to the engine.
If you can't figure out how to make it shift with the new programming.... I would just go back to the old one.
No point in changing the programming if the engine wasn't modified.
This is what I've been told by a lot of corvette forum menbers... so I'm sure you'll get the same feed back from every one.
Old Sep 12, 2003 | 07:23 PM
95_6spdvette's Avatar
95_6spdvette
Hi, ive got a 95 corvette also and am gonna use a hypertech to compliment a 160 degree thermostat, my car is running to hot for me to be comfortable! Good luck and Welcome!
Old Sep 13, 2003 | 12:31 AM
champ's Avatar
champ
On my 94, I did the following with my HP: changed speedometer since new gear was installed, lowered fan setting with 160 degree thermostat, tightened shifts up (auto) and raised top speed limiter.
Old Sep 13, 2003 | 09:44 AM
95AquaC4's Avatar
95AquaC4
With the Hypertech, there is a couple things you can do to the tranny settings. The first is changing the shift firmness. The other would be if you're a drag racer, you can adjust the MPH that it shifts in case you are shifting just before the line. You can add MPH to the shift so you can cross the line before shifting. I recommend the firmness setting, both for feel, and for practicality. You are shortening the slip time, and it may be less abusing to the tranny.
As for your shifting problem. I have learned that the 4L60E is EXTREMELY sensitive to fluid level. Either too low or too high. That's the only tip I can offer there. Good luck, hope all goes well!
Old Sep 15, 2003 | 10:51 AM
arcticvette
4th Gear
Default Re: 1995 vette with hypertech programer (95AquaC4)
Thanks for all the help guys! :seeya :chevy
To 1995 vette with hypertech programer
