Hi Guys I have a problem with my passanger side headlight it refuses to open up. I got a rebuilt motor and the relays are fine but it still wont work right, what else could be wrong its driving me nuts. thanks for the help
The motor will close under its own power but you have to open it by hand first with the light switch on, if the lights are turned off it will not let you raise the headlight :banghead:
First measure the voltage on the white/blk (neg) to green/wh (positive) wire with the headlights on. No voltage, then its a relay or wire connection. If volts is ok, then fighting opening with the headlights on and won't open can be due to the reversing contacts inside the motor not making. You can open the motor and see that the contacts are eroded so bad they don't make connection.
I had same problem replaced control mod. with no success the found fusable link separated right next to the new batt. I had just installed..........DA :banghead:
Switch the wires from the left relay to the right relay & see if the problem goes to the other headlight.
Then you will know if its a relay or a motor.
Make sure the door is not hitting the plastic cover that covers the lamp assy.
Last week I pulled my assy. three times before I realized the above mentioned was my problem. :party:
