I read most everything in the arcives and I believe I am just as confused as when I started. Some of you will I am sure say "not again" but here goes.I have a 1995 LT1 supercharged. I seem to running out of fuel at WOP at the top end of eah gear Do I need to enlarge my injectors and would 30# be to much? I am installing an adjustable regulator. I do have a 255 Walbro in my tank. When all is said and done ,will the pcm have to tuned? I'm an old carb man so please make as simple as possiable> Thanks
