Brakes pulling
Old Sep 14, 2003 | 11:52 AM
Vettewood's Avatar
Vettewood
Default Brakes pulling
Had a brake job done on all 4 corners.. replaced pads (carbon metalic) turned rotors they still had proper meat left on them flushed entire system new dot 4 new stainless lines. now when I do some hard braking the car will pull somtimes very hard almost pulling the wheel out of your hand. Do the calipers need to be replaced what do you all think.
Old Sep 15, 2003 | 12:32 PM
Steve_88's Avatar
Steve_88
Default Re: Brakes pulling (gary samuel)
Could be the calipers. I had a similar problem with my 88. I jacked up the car and spun the wheel by hand and had a friend hit the breaks and see if the calipers were working okay.
Steve
Old Sep 15, 2003 | 07:58 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I would certainly bring the car back to the sop that did the work
As to calipers being "bad", doubtfull! Sounds like you have uneven fluid pressure to one side of the system or the other, either front or rear, or one of the calipers is hanging up.
When they "flushed the brakes" with new fluid, some junk could have lodged in the lines or the caliper, have them flush it some more.
Check the pad return spring in the calipers on the offending side.
If you didn't have this problem before the brake job, you shouldn't have it after.
PS, I have experienced this problem several times and it has always been a bad brake hose where the liner inside the hose had torn and was acting as a flapper valve
:seeya
:steering:
Old Sep 15, 2003 | 09:55 PM
Vettewood's Avatar
Vettewood
I do plan to return the car to the shop. The stainless lines I refer to are the hoses (braided stainless) i will have them bleed them again......thanks
To Brakes pulling
