Correctly Jacking Car
Old Sep 14, 2003 | 01:31 PM
First C4's Avatar
First C4
Default Correctly Jacking Car
I am looking for information on how to Jack up the front and rear as well as where to place stands? My service manual only tells me about the factory Jack.
Old Sep 14, 2003 | 02:49 PM
ductape's Avatar
ductape
Cruise-In V Veteran
Default Re: Correctly Jacking Car (First C4)
I put the floor jack at the same points for lifting in one spot. Then slide a jack stand next to the jack for safety. As for lifting the whole car, or at least one end, well, I broke down and bought a 4 post lift. :D
Old Sep 14, 2003 | 08:14 PM
BookSmart's Avatar
BookSmart
Default Re: Correctly Jacking Car (ductape)
If you look at the bottom of the door on the crimp weld (the part that hangs straight down) there are 2 dots or small triangles that you should jack between. These are on the front and the back of the car close to the tires.
Only problem is the body panel hang's down a tad farther than the steel does so I usually flex the little part of it thazt hangs down. Jacking my car up this way has worked so far. I do all the work on it myself so far.
Old Sep 14, 2003 | 08:27 PM
smacko's Avatar
smacko
Default Re: Correctly Jacking Car (BookSmart)
:iagree:
DO NOT jack ANYWHERE BUT the designated points; the car must be lifted / supported ONLY on a steel cross member or else you can damage the fibreglass transverse springs!!!
The first time I jacked it, I THOUGHT the jack was supposed to go behind the arrows, WRONG! - I jacked and stopped JUST early enough to realise that I was lifting on the BRAKE LINES and squished them but just short of closing them; I WAS LUCKY...
Have a look between the arrows - you'll see that's where there's steel.
Also; make SURE that when you take car to mechanics or tyre places for wheel balances etc; that you TELL THEM (Even if they THINK they know the right way) to ONLY jack at this point! Better for them to think you're a crackpot than break a spring ($$$$). This scenario mightn't be as bad in the USA but over here in Australia where there are virtually no corvettes, they simply don't KNOW this unless you tell them.
YES; You WILL flex the skirt and crack a bit of paint, but thats life.
Hope that helps
Old Sep 14, 2003 | 08:31 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Correctly Jacking Car (smacko)
I use a Jack-A-Vette for the rear
Old Sep 14, 2003 | 09:44 PM
montie98's Avatar
montie98
Default Re: Correctly Jacking Car (Mr Mojo)
Whats the difference between the Jack a Vett and a regular jack?
Old Sep 14, 2003 | 10:02 PM
First C4's Avatar
First C4
Default Re: Correctly Jacking Car (montie98)
What is that connected to the Jack and where does it go?
Can you place the jack on the front crossmember (theres a piece of steel covering the spring that crosses both front wheels)and lift both front wheels at the same time?
There has to be another way besides those arrows, bending and cracking dont seem like the right way. With the emergency jack right, with a floor jack no.
Old Sep 14, 2003 | 10:32 PM
shotchkiss's Avatar
shotchkiss
The front can be lifted by jacking up the front crossmember according to my service manual. You might have to drive it up on some boards to get the jack under the car.
Old Sep 14, 2003 | 10:42 PM
redvettetuck's Avatar
redvettetuck
Cruising
totaly concour floor jack lift points and then a must jack stands at a frames :auto:
Old Sep 14, 2003 | 10:56 PM
Mr Mojo's Avatar
Mr Mojo
Default Re: Correctly Jacking Car (shotchkiss)
:iagree: That's what I do if I need to remove the front wheels.
The Jack-A-Vette replaces the round saddle on the floor jack with an upside down "T" shaped piece of metal which fits between the exhaust pipes(as shown in the pic) and lifts the car by the diff. carrier.
Old Sep 14, 2003 | 11:07 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Mojo: where to get the jack a vette...?
Old Sep 15, 2003 | 07:40 AM
Mr Mojo's Avatar
Mr Mojo
Default Re: Correctly Jacking Car (vinnies87)
Vinnie, no idea, mine was given to me.
Old Sep 15, 2003 | 08:51 AM
luvmy92's Avatar
luvmy92
This is how I jack mine...
http://forums.corvetteforum.com/zerothread?id=637182
Mike
Old Sep 15, 2003 | 09:03 AM
Arisa's Avatar
Arisa
Default Re: Correctly Jacking Car (luvmy92)
I didn't see it in here anywhere but pop the hood also anytime you jack it up, It doesn't need to be raised just popped loose !
Old Sep 15, 2003 | 09:37 AM
smacko's Avatar
smacko
...If you haven't already found it mate, check out;
Jacking a C4 at the middle of the frame rail POSTING...
:cheers:
Old Sep 15, 2003 | 11:31 AM
HTRK-1's Avatar
HTRK-1
I use the Jack-a-vette for the rear and a flat jack pad under the front cross member for the front. If I'm changing oil, I just lower the car onto my rino ramps. I do need to drive up on 2x6's to get the jack under both front and rear. You can get a jack-a-vette from Corvette central. Just search under C4's a type "jack". It's kinda pricey at $50, but once you use it, it's worthe every penny.
:cheers:
Old Sep 15, 2003 | 11:51 AM
vinnies87's Avatar
vinnies87
Knew i'd find it somewhere in my listings... origional post at the forum here.
Jack adapter for vette's:
http://www.corvettegadgetman.com/products3.html
$35.00......
To Correctly Jacking Car
Old Sep 15, 2003 | 12:33 PM
Jimbo93's Avatar
Jimbo93
I also open my rear window hatch to make sure it doesn't get broken due to uneven pressure. :thumbs: :seeya
Old Sep 15, 2003 | 01:03 PM
Flame Red's Avatar
Flame Red
Also remember that you can use a hockey-puck with a regular hydralic jack at the factory lift points to make it much easier and prevend damage to your finish.
Old Sep 15, 2003 | 01:05 PM
vinnies87's Avatar
vinnies87
Default Re: Correctly Jacking Car (Flame Red)
Now thats one i've never heard of.... so off to the sporting goods store.... :cool:
