Fuel Canister problem?
Old Sep 14, 2003 | 08:33 PM
rsafier's Avatar
rsafier
Default Fuel Canister problem?
Okay was at my AutoX today and started leaking flew out of the carcoal cansister located in the front drivers side of the car. There is a drain tube that goes to the outside of the car. It first was a small drip, by the 4th run it was leaking at 2-3 oz a minute! Safty guys almost threw me out. Plugged it with a bolt, but that sure isn't a fix. What could be wrong? Need to look at my shop manual to see how that thing works.
Other then that the AutoX was great! Got 1st in AS, beating out those pesky Evos and STIs :)
Old Sep 15, 2003 | 12:13 AM
rsafier's Avatar
rsafier
Default Re: Fuel Canister problem? (rsafier)
TTT
Old Sep 15, 2003 | 12:57 AM
rsafier's Avatar
rsafier
Okay, been reading about the EECS system. Doesn't really seem to explain my problem, it shouldn't be leaking fuel like it was. Plus the Haynes manual doesn't even mention the lower drain tube.
I am wondering if I even need the EECS system. Can I just remove it and be okay?
To Fuel Canister problem?
