1.6 RR
Old Sep 14, 2003 | 09:31 PM
bstirn's Avatar
bstirn
Default 1.6 RR
Will 1.6 RR fit under stock 92 valve covers. And how much do they cost with new valve springs installed . Thanks
Old Sep 14, 2003 | 09:50 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: 1.6 RR (bstirn)
You should also replace the upper & lower seals along with the keepers.
You should be able to install a set of ProMagnum self-aligning 1.6:1 RR, springs, seals and keepers for under $400-500, including a set of FelPro Permadry gaskets.
The L98 valve covers need to have the drip tabs ground down and the bolt towers reduced in width for clearanced, but I'm not sure about the LT1.
Old Sep 14, 2003 | 10:10 PM
Nathan Plemons's Avatar
Nathan Plemons
Stock 92 valve covers will need to be modified.
To 1.6 RR
