interior rubber coating
Old Sep 15, 2003 | 05:01 PM
spinedoc's Avatar
spinedoc
Default interior rubber coating
my 96 seems to have a rubber type coating on the center console area, and it is peeling off a bit. Can this be repaired, or replaced?
Old Sep 15, 2003 | 05:27 PM
bogus's Avatar
bogus
Default Re: interior rubber coating (spinedoc)
someone posted a new stuff they found, but requires a compressor to spray on.
I cannot remember what it was called, cause I was interested in it, too.
I have had some success with "Plasti-dip". Spray on or in a can - for brush or dipping.
Plasti-Dip is available at Lowes.
Old Sep 15, 2003 | 10:59 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
I just peeled mine off, sanded and repainted black, instead of the grayish-black that the rubber stuff is. Looks better I think :D
Old Sep 16, 2003 | 01:37 PM
John Row's Avatar
John Row
I used the spray can Plasti-Dip. It's a shade blacker than stock.
I'm not real pleased with the longevity. It's been in about 6 mos and it's starting to peal.
Maybe if I did a better prep-job before I painted it and used more than 3 coats it would be better. I just stripped the old stuff, washed it, and did a light steel wool rub.
It looked OK when it was fresh.
I think there's a TECH TIP for this job.
Old Sep 16, 2003 | 07:43 PM
Thanatos69's Avatar
Thanatos69
check out the following thread I created a while ago.
http://forums.corvetteforum.com/zerothread?id=642134
To interior rubber coating
