octane booster Which one?
Old Sep 15, 2003 | 07:43 PM
gwalsh88's Avatar
gwalsh88
Default octane booster Which one?
As some of you may know I had a slight problem with knocking and pinging after getting a tank of 87 Octane. I decided to buy some octane booster. There are several brands on the market but none except the Prestone product tell you how much the octane rating will rasie. The Prestone product said it will raise by 10 levels with each level represented by .1 which means my 87 gas would only be 88 octane after the additive. I know 104 octane booster is the most expensive and the name would suggest that it goes to 104 octane by I find that very hard to believe. Any thoughts?
Old Sep 15, 2003 | 07:53 PM
timallard's Avatar
timallard
Default Re: octane booster Which one? (gwalsh88)
I am in Australia, but over here the best stuff is Nulon Pro Strength. There was a write up in a hot rod mag in which they had tested several octane boosters. This one gave the best results but was the most expensive. I use it when I race the car. I don't know if that brand is available over there.
Cheers
Old Sep 15, 2003 | 11:35 PM
blk95's Avatar
blk95
Default Re: octane booster Which one? (timallard)
Cheers //quote
Ya, we have sunoco gold 94 man the thing flys :rolleyes: :rolleyes:
I know somewhere in the States they sell 100oct.
[Modified by blk95, 5:47 AM 9/16/2003]
Old Sep 16, 2003 | 06:41 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: octane booster Which one? (blk95)
They used to sell 100 octane at select 76 stations. I don't know if they do it anymore though.
Check the website. Although I'm not even sure they have 76 stations outside CA do they?
That stuff in a bottle is CRAP. Most of it just claims to de-carb your combustion chamber to reduce detonation, therby decreasing your octane requrements. It doesn't actually increase the octane rating of your fuel.
Think about it this way.. in order to add ONE PINT to 20 GALLONS of fuel, and raise it from say, 91 octane, to 92 octane, that pint of octane booster would need to be 250 octane. And it isn't.
'Nuff said. :bs
Old Sep 16, 2003 | 11:10 AM
John Row's Avatar
John Row
At the end of this article http://www.idavette.net/hib/fuel/index.htm, they mention that NOS Octane Booster tested reasonably well.
[Modified by John Row, 8:10 AM 9/16/2003]
Old Sep 16, 2003 | 12:45 PM
Nathan Plemons's Avatar
Nathan Plemons
Actually by point they mean .1 So if you raise your octane rating one point you are going from 87 to 87.1. Sounds pretty crappy huh? Your best bet would be to top the tank off with higher octane fuel.
Go siphon about half of your gas out, use it in the lawnmower. Then carefully drive to the gas station and fill it up with premium. Congrats you will essentially have a tank of mid grade and it'll cost you far less than all the octane boosters would.
Old Sep 16, 2003 | 12:55 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: octane booster Which one? (CentralCoaster)
I've used "104+ Plus" brand in the yellow bottle before to great effect. It's got the "kick-gas" guarantee, too! :thumbs: :chevy
Old Sep 16, 2003 | 03:23 PM
RVY's Avatar
RVY
Default Re: octane booster Which one? (onedef92)
Go to your local paint store and buy a gallon of Tolouine. Pour it into your gas tank filler tube (use a funnel) and your problem is solved.
Any questions---do an archive search.
Old Sep 16, 2003 | 03:32 PM
HC4-Vette's Avatar
HC4-Vette
Default Re: octane booster Which one? (RVY)
Here in Indy, we have quite a few stations that sell CanAm 105 octane right out of the pump. Others that sell 100 octane----but then again Indy is the racing capital of the world :lol:
Old Sep 16, 2003 | 07:47 PM
gwalsh88's Avatar
gwalsh88
Thanks for the info :cheers:
Old Sep 16, 2003 | 08:42 PM
95AquaC4's Avatar
95AquaC4
Default Re: octane booster Which one? (John Row)
And the one in the black box actually contains Nitro Methane! :thumbs:
Old Sep 17, 2003 | 04:28 AM
jtfrog's Avatar
jtfrog
This is something i am going to try. After doing lot of search on the net people say to use 10% tolune as an additive. They say a good mix is
100 oz. of toluine = boost
25 oz. mineral spirits = cleaner
3 oz. of tranny fliud = lubricant
Old Sep 17, 2003 | 04:29 AM
jtfrog's Avatar
jtfrog
Default Re: octane booster Which one? (jtfrog)
One thing I forgot is in the above post that this makes 16 8 oz. bottles. If anyone has tried this let me know
Old Sep 17, 2003 | 08:09 AM
silver84's Avatar
silver84
The stuff sold in pint cans...fraud.
Get the best pump gas you can find, then add 30% toluene.
To octane booster Which one?
