Electrical Problem
Old Sep 15, 2003 | 07:45 PM
ckrueger's Avatar
ckrueger
Cruise-In I Veteran
Default Electrical Problem
My friend has a 89 with an electrical gremlin. the coutesy lights behind the seat will not go out, even with the key off. can some help me out???????????? :rolleyes: :banghead:
Old Sep 15, 2003 | 08:48 PM
Kens86's Avatar
Kens86
Default Re: Electrical Problem (ckrueger)
Is the headlight switch turned all the way to the left so that the interior lights stay on?
Old Sep 15, 2003 | 09:07 PM
ittlfly's Avatar
ittlfly
Default Re: Electrical Problem (Kens86)
:iagree: Yep, it's the little things. :D
Old Sep 15, 2003 | 10:58 PM
jfb's Avatar
jfb
Bad door switch, or bad courtesy timer module.
Old Sep 15, 2003 | 11:18 PM
SunCr's Avatar
SunCr
Cargo lights also have a path to ground through the hatch switch. Make sure the hatch is closed. If it's slightly open, the cargo lights will stay on. Otherwise, that switch probably needs to be replaced. Access by removing the release handle for the retractable cover and then remove the molding.
To Electrical Problem
