FX-3 Suspension 93 Vette
Old Sep 15, 2003 | 10:55 PM
oldyaller93vette's Avatar
oldyaller93vette
1st Gear
Default FX-3 Suspension 93 Vette
What is the problem with this suspension when the "check suspension" message appears on the message display? :rolleyes:
Old Sep 16, 2003 | 07:27 AM
Aaron71771's Avatar
Aaron71771
Default Re: FX-3 Suspension 93 Vette (oldyaller93vette)
Could be an actuator on a shock, or the FX3 controller.... Sometimes mine will act up when I first start it after jacking the car up. Usually a restart will fix it. Hopefully someone will post how to get the codes out of the FX3 controller and you can narrow down the problem.
Old Sep 16, 2003 | 08:13 AM
bad-zr1's Avatar
bad-zr1
Default Re: FX-3 Suspension 93 Vette (Aaron71771)
Paper clip or jumper from pins A to C and turn the key on. Each code will flash 3 times starting and ending with 12.
:steering:
To FX-3 Suspension 93 Vette
