Adjusting roller rockers -
Old Sep 17, 2003 | 10:25 AM
HeeHaw89's Avatar
HeeHaw89
Default Adjusting roller rockers -
I am using Pro Magnum 1.6's and was wondering if these need to be adjusted from time to time or not at all.
I know there are a ton of people here using them. Are you checking them? If so, how often?
Old Sep 17, 2003 | 10:30 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Adjusting roller rockers - (HeeHaw89)
Well I'm not using the pro magnms, I'm using Scorpion 1.7 rockers but the principal is the same. I check mine whenever I feel like there is excessive noise coming from the valve covers. Other than that if it ain't broke, don't fix it.
Old Sep 17, 2003 | 10:40 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I have run the 1.6:1 ProMagnums for several years and they sound fine and I get no valve float, so the valve covers stay in place.
I figure I didn't service the OEM rockers so these should be at least as good.
Old Sep 17, 2003 | 10:44 AM
HeeHaw89's Avatar
HeeHaw89
Default Re: Adjusting roller rockers - (Nathan Plemons)
Mine were rather noisy (compared to stock) immediately upon installation so its hard to gauge if they are getting out of adjustment just on sound alone.
I guess the key word in your response is "excessive", which I don't believe to be the case at this time.
I agree if its not broke don't fix it, but I was just wondering if it should be considered a preventative maintenance item.
Old Sep 17, 2003 | 01:02 PM
65Z01's Avatar
65Z01
Mine seemed quieter than the OEM rockers and I've had the valve covers off since installation so feel a secure in the setup.
I wonder if Comp Cams has any info on their site as to maintenance and/or inspection intervals for their ProMagnums; there is no such info in their old catalog.
Old Sep 17, 2003 | 10:33 PM
pablocruise's Avatar
pablocruise
I've checked mine after various R/R's on engine components and or just for my peace of mind using the running method. Can rest easy knowing I did it and it's in check. Only cost me time and effort. I'd say do it. Just so you know you did it and set it to where you like.
To Adjusting roller rockers -
