90 sterring wheel loose
Old Sep 17, 2003 | 12:03 PM
Bump's Avatar
Bump
Default 90 sterring wheel loose
New to vette ownership, never worked on cars. I have a 90 vette that is a basket case, first question ( many more to come ). 90 has a very loose sterring wheel, how do I disable the air bag system and get inside to tighten the wheel?
Old Sep 17, 2003 | 12:57 PM
Red90Coupe's Avatar
Red90Coupe
Default Re: 90 sterring wheel loose (Bump)
First, welcome to the forum.... :cheers: I think you will really like your 90 after you get it whipped back into shape!! Use the "search" archive function with "steering" as the search keyword and you will find many threads about repairing loose steering columns since this seems to be a common problem, probably due to using the steering wheel to help push ourselves out of the cockpit.
Old Sep 17, 2003 | 12:59 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Is it loose as in it moves up and down.... or loose as in the steering response is non existant?
Old Sep 17, 2003 | 01:11 PM
Bump's Avatar
Bump
Default Re: 90 sterring wheel loose (Jeffvette)
moves up and down side to side. With just a little downward pressure the tilt will drop a few notches also.
Old Sep 17, 2003 | 01:22 PM
Jeffvette's Avatar
Jeffvette
There are a couple of Torx head bolts that secure the column to the frame of the dash. I would check those first. You have to remove the hush panel, and maybe the metal frame to get to them.
Old Sep 17, 2003 | 04:51 PM
Bump's Avatar
Bump
the column bolts are tight. all movement is in wheel itself. How do I disable the air bag and remove it where I can get underneath the wheel? :smash:
Old Sep 17, 2003 | 05:11 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: 90 sterring wheel loose (Red90Coupe)
:iagree: Search the archives with steering as the key word, select both title and body text search.
To 90 sterring wheel loose
