How many pounds? 90 L98 fuel injectors.
Just to find out ahead of time. How many pounds of pressure/hr. does stock 1990 L98 fuel injectors produce. If I need to replace them inwhich I may have to from a earlier question I had on the Forum, i want to keep my eyes open. I just saw a new set of eight accel 30 pounds going off shortly on ebay fairly cheap. Thanks vettefast :chevy
Cruise-In II Veteran
Re: How many pounds? 90 L98 fuel injectors. (vettefast)
They are 22lb/hr full flow at 44spi.
A set of 30lb/hr injectors would be way too much for even a lightly modded L98.
24#s is a overkill it will work but it will run rich unless you get a custom prom go to 5 0 motorsports he has the stock 21# injectors new for $180.00
Received 1,401 Likes
You can use the 24's, you just need to buy an adjustable pressure regulator and turn it down some to help the ECM compensate.
Location: Minnesota in the summer, Las Vegas in the winter
Re: How many pounds? 90 L98 fuel injectors. (6spd)
I looked up " 5 0 motorsports" and it did not come up on the web. Is there a web site or a different name I can look up? Thanks! :nonod: Vettefast
I just bought fms 24# injectors from jegs along with a regulator and gage.
I cant wait till they come so I can get it running again. :)
Re: How many pounds? 90 L98 fuel injectors. (tlc85)
I just found ford svt racing 24#lb/hr in Summit for $219.95. A friend of
mine used them in his supercharged 86 with the regulator and he says they work great. :auto:
When you get them installed let us know how it works out! If it runs great or to rich or if there are any adjustments you had to make to make it run better! Thanks! :cheers: Vettefast
