91 VETTE KNOCK RETARD
Old Sep 17, 2003 | 10:35 PM
6spd's Avatar
6spd
Default 91 VETTE KNOCK RETARD
I NOTICED TODAY WHILE DRIVING MY KNOCK RETARD WENT FROM 1 TO 2 BACK TO 1 THE TEMP WAS ABOUT 210 DEGREES THE KNOCK SENSER IS NEW THAT ALSO SHOWED 1 THEN BACK TO ZERO IS THAT NORMAL?? MY TIMING IS SET AT 6 DEGREES MY FUEL PRESSURE IS SET AT 42PSI WITH LINE OFF THE BLM'S ARE 128 I DO REMEMBER WHEN I PUT THE NEW SENSER IN I MADE IT TIGHT I DON'T KNOW IF THAT'S CAUSEING IT?? WHAT OTHER THINGS CAN CAUSE THIS??? EVERYTHING IS NEW SENSORS ALL TUNE UP PARTS AND FUEL PUMP.FILTER
Old Sep 18, 2003 | 12:14 AM
scorp508's Avatar
scorp508
Default Re: 91 VETTE KNOCK RETARD (6spd)
Is it a constant 1 or 2 degrees of retard or just a spike here and there? It could just be the engine temp in combination with air conditions and gas quality that day causing it.
