I had my base timing set to 6 Degrees but after reading on someones web sight that they have their timing set to 11 degrees I decided to do the same.
RPM's go's trough faster in all gears and pulls hard.Just wondering what everyone else is running for timming and if I should leave at 11 degrees
Do you have a TPIS chip as well? TPIS recommends leaving the timing at 6 because their level 6 PROM is programmed for that. I have the zz9, miniram, and all the other goodies plus ported stock aluminum head with 2.02 valves. I left my timing at 6 not just because of the TPIS chip but also because I have 10.25:1 compression, and I am trying to be careful not to set off the knock sensor. I just started it after the engine rebuild last night for the first time, though, so I don't have much actual experience to report on, but I'll be glad to let you know more when I take it out this weekend. By the way, how much vacuum are you pulling on your motor at idle?
i think a 91 with a good tune, stock chip, and premium fuel will take 10* initial with no problems. if you have a custom chip, check with the manufacturer. they usually advance the timing to the max though and timing should be set to stock.
[Modified by neverendingproject, 5:25 PM 9/18/2003]
I have the ZZ9 with AFR heads and the super ram. a bit over 10:1 compression
I have my timming cranked up to about 10-12 degrees.
I recently got some knock when it was 103 degrees out here, so I backed it off a bit, but when cold, it loves the timming. this was with the CA 91 octane too.
I wouldn't worry too much about 10.25:1 compression TPIS say you can run up to 11:1 on premium pump gas with a zz9 cam & aluminum heads :steering:
