exhaust manifold noises
Old Sep 19, 2003 | 10:00 AM
corvette90's Avatar
corvette90
Default exhaust manifold noises
ive a clicking sound under my car, that im fighting against since i bought it..
checked everything, like compression, spark plugs, injectors, bearings, aso, all the ususal clicking stuff..and everything ok..
today, i tested again, and narrowed the problem down to the exhaust
im pretty sure, i´ve no exhaust leaks, and (stock) manifolds are not broken
also, i know i have a different cam in it, not stock, because ive a lope at idle,
and also when i take off its not the strongest, but when rpms comes up to 2000 it starts pulling like a beast...some passengers and stop light competitors knows this :D
can this cam cause clicking noises in the downpipes??
answers would be nice
thank you
Old Sep 19, 2003 | 03:53 PM
corvette90's Avatar
corvette90
Default Re: exhaust manifold noises (corvette90)
anybody?? :confused:
Old Sep 20, 2003 | 01:47 AM
BAM92's Avatar
BAM92
Is this the clicking you here when you turn the car off after driving that comes from exhaust?
Old Sep 20, 2003 | 03:15 AM
corvette90's Avatar
corvette90
Default Re: exhaust manifold noises (BAM92)
no, i dont mean the clicks of a hot exhaust, i mean the clicks when engine running..clicking like firing pulses..
as i said no leak in the exhaust, just if this noise can be caused by a cam, ??
Old Sep 20, 2003 | 05:43 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
My vette's exhaust sounds like a John Deere. Is that what you're talking about? I've pulled the entire exhaust off twice, replaced the header gaskets, and have had no improvement.
This is with a stock cam. It's really getting on my nerves. Happens under slight load at 2000-2300 rpms. Perhaps its the AIR system that has a leak. :lurk:
Old Sep 20, 2003 | 05:56 AM
corvette90's Avatar
corvette90
Default Re: exhaust manifold noises (CentralCoaster)
hi..THAT is what i´m talking about
mine goes from idle, and when i rev the enigne i cannot hear it anymore..also i have a very aggressive sound from left and right header area when i accelerate..no knocking or pinging, just aggressive :D
but...when i idle, or under crusing conditions i have the clicking noises...
maybe we must learn to live with them... :confused:
Old Sep 20, 2003 | 09:11 AM
ittlfly's Avatar
ittlfly
I see you didn't mention that you replaced / checked plug wires. I'm wondering if that clicking isn't a spark jumping to ground.
Old Sep 20, 2003 | 03:34 PM
corvette90's Avatar
corvette90
Default Re: exhaust manifold noises (ittlfly)
i have new wires in it, about a year old..do you mena, spark is jumping around outside??
also plugs are new...
Old Sep 20, 2003 | 03:54 PM
ittlfly's Avatar
ittlfly
I was thinking a frayed / cut wire allowing the spark to jump to ground. Just a thought.
Old Sep 20, 2003 | 05:21 PM
CentralCoaster
I had a plug wire arcing to the plenum right by the distributor,
but this was making a distinct 'snap' type noise.
The exhaust tick is more muffled, but still high pitched.
Old Sep 20, 2003 | 05:59 PM
corvette90's Avatar
corvette90
ok, i ´ll have a sharp look on it, maybe it helps..thank you
To exhaust manifold noises
