Codes:15, 18, 22 and 64
Old Sep 21, 2003 | 01:51 PM
Want2Myself's Avatar
Want2Myself
1st Gear
Default Codes:15, 18, 22 and 64
vette started running bad, assumed fuel filter issue. I am getting the following codes 15-Engine Coolant temp Sensor, 18-Injector circuit, 22-Throttle Position sensor Circuit high volt and 64-Heated Oxygen Sensor Circuit Rich. Any suggestions? :banghead:
Old Sep 21, 2003 | 02:39 PM
bogus's Avatar
bogus
Default Re: Codes:15, 18, 22 and 64 (Want2Myself)
hm. I would start by replacing the o2 sensors.... work back from there.
they are cheap enough, and not that hard. they are located on the down pipe from the manifold before the cats.
