WHAT GEARS DO I HAVE?
Old Sep 22, 2003 | 12:27 AM
007rollie's Avatar
007rollie
Default WHAT GEARS DO I HAVE?
89 Auto 71 m.p.h. turning 2500 r.p.m.
Old Sep 22, 2003 | 12:57 AM
blk95's Avatar
blk95
Default Re: WHAT GEARS DO I HAVE? (007rollie)
If it was a 6sp just put it in 4th and run it to 75mph, that should give you an idea ratio.
Sorry, it don't know the Autos'
Old Sep 22, 2003 | 09:12 AM
Steel Blue 91's Avatar
Steel Blue 91
Mine runs ~1900 @ 70MPH and I have stock 2.59 gears. I would guess (a real SWAG) 3.07 for yours. You can check the RPO codes to see what it came with from the factory.
Old Sep 22, 2003 | 09:25 AM
owen lancaster's Avatar
owen lancaster
I had 96 with Auto and 3.07. In OD mine was not that high in the RPM range. I would guess 3.45 or 3.73's. But that's just a guess. I think at about 70 mph mine was turning under 2000.
Old Sep 22, 2003 | 09:30 AM
MrNuke's Avatar
MrNuke
Default Re: WHAT GEARS DO I HAVE? (owen lancaster)
I have 3.45's and am running 2350 at 70mph.
Old Sep 22, 2003 | 09:46 AM
vader86's Avatar
vader86
You sound like you have 3.54 or 3.73. Going by what Nuke said, probably 3.73:1
Old Sep 22, 2003 | 09:47 AM
Red Tornado's Avatar
Red Tornado
Default Re: WHAT GEARS DO I HAVE? (MrNuke)
I have 3.33's and I run about 2400-2500 at 70 mph.
Old Sep 22, 2003 | 12:59 PM
MrSpeedyBob's Avatar
MrSpeedyBob
Rolling diameter of stock tires is about 24.8 in. Transmission ratios on the 700R4 and 4L60 are as follows: 1'st gear = 3.07, 2'nd gear = 1.63, 3'ed gear = 1, 4'th gear = 0.7 Use the following formula to find rear end ratios. (RPM*Tire Diameter)/(Trans ratio*MPH*336.16)
So:
007rollie (2500*24.8)/(.7*71*336.16)=3.71
Steel Blue 91 (1900*24.8)/(.7*70*336.16)=2.86
MrNuke (2350*24.8)/(.7*70*336.16)=3.53
bradvette (2450*24.8)/(.7*70*336.16)=3.69
Does this tell you something about the accuracy of our tacks? They all read a little high.
Old Sep 22, 2003 | 02:06 PM
MrNuke's Avatar
MrNuke
Default Re: WHAT GEARS DO I HAVE? (rkessel)
Yea I dun trust my tach either. I'm getting a small analog tach just to see how much my stock LCD one is off by.
I knwo I have 3.45's though, so either the tach was off or I have smaller wheel/tire than stock. (I have aftermarket 17" and 275/40/17 tires)
Old Sep 22, 2003 | 02:32 PM
scorp508's Avatar
scorp508
Depends on the year. My stock '87 rim/tire combo was 26", but the new grandsport stuff is like 25.8".
Old Sep 22, 2003 | 07:12 PM
6spd's Avatar
6spd
look in your center console you should have a code
Old Sep 22, 2003 | 11:33 PM
black85vette's Avatar
black85vette
Default Re: WHAT GEARS DO I HAVE? (6spd)
after lifting the rear wheels off the ground put it on jack stands. mark the drive shaft with a line, mark one of the wheels .slip the trans into neutral.turn the drive shaft counting the turns until the wheel makes one complete revolution this will give you the ratio.
Old Sep 23, 2003 | 12:55 AM
ciscokid's Avatar
ciscokid
Under your center console you will have a decal with various codes. The code your looking for starts with a G. This is an RPO code. Here are the codes and what they equate to for the Dana 36:
Ratio= 2.59 RPO=GM1
Ratio= 2.73 RPO=GU2
Ratio= 3.07 RPO=G44
Ratio= 3.31 RPO=GW4
For the Dana 44:
Ratio= 3.07 RPO=G87
Ratio= 3.33 RPO=GT7
Ratio= 3.45 RPO=GM3
Ratio= 3.54 RPO=GHO
Hope this helps.
Old Sep 23, 2003 | 01:15 AM
BowTieBlood's Avatar
BowTieBlood
Default Re: WHAT GEARS DO I HAVE? (ciscokid)
In my '95 auto at 70 mph I'm turning about 2000 or close to, I have 3.07s
To WHAT GEARS DO I HAVE?
