It depends on your compression ratio. The less comp the more boost you can run, thus giving more HP (You probably already knew that)
Considering you have a unique setup, I would definitely spare no expense in monitoring equipment like a Wideband O2 and especially an EGT which will give you a good idea of your mixture and detonation probabilities.
ok.. im not sure about what comp im going to run. You got any experince on using diffrent comps?
Personally no, but give a HiPro shot a call who specializes in that. like Rich at http://www.built4speed.com.
Basically it's a balance and is different for all applications. It's a trade off. Since it's a centrifugal S/C we're talking about, you don't benefit from the low RPM torque and that also depends on the impeller and gearing of the s/c. Therefore, it depends how you want to balance the power through the RPM's.
Depending on how stout you build the motor will most likely determine how much power you're going to be able to produce, and that will let you know what psi you can run, which will let you decide what compression ratio you can go with to balance the power band.
