what pistons?
Old Sep 23, 2003 | 11:57 AM
devilfish's Avatar
devilfish
Default what pistons?
im going to bore my block to a 355 and use strong pistons.
I will keep my crank and rods.
What pistons do you recomend?
I going to run a low comp around 8,9:1. ( Going with SC later )
Old Sep 23, 2003 | 12:02 PM
vader86's Avatar
vader86
Default Re: what pistons? (devilfish)
forged-JE, Ross, SpeedPro, etc.
just make sure theyre forged
you can pick one to keep compression where you need it
Old Sep 23, 2003 | 12:03 PM
devilfish's Avatar
devilfish
Default Re: what pistons? (vader86)
thank you sir :flag
Old Sep 23, 2003 | 12:05 PM
devilfish's Avatar
devilfish
another thing..
Can my stock rods and crank with ARP bolts handel 400hp+ shifting at 6000rpm?
Old Sep 23, 2003 | 12:30 PM
Goody's Avatar
Goody
With a SC added too?? I'll say yes but only if the clearances are spot on and the rotating assy is balanced very well.
Old Sep 23, 2003 | 12:59 PM
devilfish's Avatar
devilfish
Default Re: what pistons? (Goody)
yes everything is going to be balanced and new clev bearings installed. Evertying is going back on with arp bolts.
Old Sep 23, 2003 | 02:12 PM
MrJay's Avatar
MrJay
It is going to be hard for you to get that compression with the heads that you have now, you will have to have pistons what are dish and with more then -20cc
If you are not going to change more then the pistons then just go with SpeedPro/TRW forged pistons.
SRP, Pro Tru and Probe are all really good pistons too.
Jay
[Modified by MrJay, 2:03 PM 9/23/2003]
Old Sep 23, 2003 | 02:24 PM
devilfish's Avatar
devilfish
Default Re: what pistons? (MrJay)
the comp im going to use isent really set yet. So any tips is very helpful...
I think my rods and crank all ballanced and tight with ARP bolts would hold up nice.
My goal is 450 hp with a lt1 intake+ my other mods in sign and a SC with water injections.
thanks
Old Sep 23, 2003 | 03:12 PM
MrJay's Avatar
MrJay
How many CC are your heads?
Jay
Old Sep 23, 2003 | 03:23 PM
C10 JDR's Avatar
C10 JDR
So what kills hypereutectic or standard cast pistons?
Is it torque, comp. ratio, revs, or what?
Old Sep 23, 2003 | 03:55 PM
vvv90's Avatar
vvv90
Default Re: what pistons? (britvette)
I'd say the biggest enemy is detonation.
Old Sep 23, 2003 | 04:33 PM
C10 JDR's Avatar
C10 JDR
Default Re: what pistons? (vvv90)
I would say your right, but even forged pistons don't like much of that.
Forged pistons are, I am sure all will agree, superior to cast.
To recommend forged (whilst undoubtedly true) reminds me of Oscar Wilde-
"I am easily satisfied - just give me the best"
But what I am wondering is at what point do you need the rattle and expense of forged, and how do you gauge that point - CR or what?
[Modified by britvette, 10:38 PM 9/23/2003]
Old Sep 23, 2003 | 04:42 PM
vvv90's Avatar
vvv90
Yes, however forged pistons don't crater and flake like cast pistons due under minor amounts of knock.
The other weak link, however, is the cast rings.
Forged pistons are, I am sure all will agree, superior to cast. but what I am wondering is at what point do you need the rattle and expense of forged, and how do you gauge that point - CR or what?
It has more to do with all those things. I have a friend whose got a 600HP smallblock running hypereutectic pistons at 7500RPM. Forged on the otherhand is lighter and better for high reving strokers requiring a lighter reciprocating assembly. (And we already covered boost and detonation)
So in short, it depends on the application. What might be good for my friends 600HP motor, isn't good for a 434 ci stroker with N2O or F/I.
Old Sep 23, 2003 | 04:53 PM
C10 JDR's Avatar
C10 JDR
Ok. With you so far, but not many of us have 600 horse motors or big nitrous strokers, so are us poor folks with say up to a 383 with 400 ponies likely to be OK with hypereutectic. I just have standard slugs in mine (admittedly with probably 300hp or less), and I haven't broken one yet. (and believe me- I've tried!)
Just looking for some kind of rule of thumb :confused:
Old Sep 23, 2003 | 05:02 PM
vvv90's Avatar
vvv90
O.k. now your question is more involved with WHICH hyper piston to go with.
I'm not familiar with the HP constraints on the stock pistons. But if you're machining a new engine you'll need new pistons and the price difference between hyper and forged is IMO marginal, but that's just me.
N/A w ~10.5-10.8:1 400HP, hyper pistons will be o.k.
The pistons my buddy got were stronger than stock pistons though. I'll see if I can find out who makes them, but the only reason he went with them, is because he couldn't get forged pistons for a Ford 347 .030 over, and the hypers were available and appropriate.
Old Sep 23, 2003 | 05:10 PM
C10 JDR's Avatar
C10 JDR
Thanks triple v. Interesting info.
Old Sep 23, 2003 | 09:18 PM
neverendingproject's Avatar
neverendingproject
wiseco makes forged pistons w/a 20cc dish for blower apps. i got mine from www.dirttrackthunder.com for less than $500, with moly rings, pins and double spirolocks.
To what pistons?
Old Sep 24, 2003 | 04:46 AM
devilfish's Avatar
devilfish
Default Re: what pistons? (neverendingproject)
so do you agree that the weak part in a stock engine is the pistons and the rings?
rpm kills rods and cranks, and im not taking it over 6000rpm so that would hold nice with som arp bolts.
Old Sep 24, 2003 | 10:33 AM
vvv90's Avatar
vvv90
On a Blown or n2o app YES!
On an N/A app NO!
Old Sep 24, 2003 | 12:45 PM
devilfish's Avatar
devilfish
so what on a N/A?
