A/F Ratio
Old Sep 23, 2003 | 08:12 PM
black_89_vette's Avatar
black_89_vette
Default A/F Ratio
Other than a wideband sensor during a dyno run, can you find your A/F ratio from using a Snap On scan tool?
I think I remember people saying that they use DiaCom or whatever and have that plugged into their laptops for reading engine data.
I don't have a laptop, but I have a mechanic that has a SnapOn scanning tool. From this, I've seen him read quite a bit of engine data, but can A/F ratio be read using it?
Old Sep 23, 2003 | 08:24 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: A/F Ratio (black_89_vette)
You can get an idea, but it's very vague.
Old Sep 23, 2003 | 09:31 PM
neverendingproject's Avatar
neverendingproject
i think it only gives you o2 millivolts , which some members(not me) can convert for you. the problem is the accuracy of your stock o2 sensors.
Old Sep 24, 2003 | 12:21 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
A good scan tool will show you O2 voltage readings from the O2 sensor. From this data you can:
1) at part throttle in closed loop see if the values are swinging between about .4-.9 Vdc which means the ECM is maintaining the stoch A/F ratio.
2) at WOT see if the value is around 900mV meaning about 12.8:1 ratio which is about right for best power.
While it's true that the stock O2 sensor isn't accurate at WOT, it will still give a good idea if the A/F ratio is about right for best power.
Old Sep 24, 2003 | 12:47 AM
Switch's Avatar
Switch
According to all I've read is oxygen sensors are only good at values of air/fuel of 14.7:1 and are very non linear.
I'm not sure you would know if you have 12.5 or 13.5 to 1 with 800mv at WOT. And that's a big difference in exhaust temp.
I think the best you could do is find a gross problem with it.
Just my 2 cents.
To A/F Ratio
