I used the LT4 springs, lightwieght retainers, and keys.
And don't forget the shims. I changed the valve stem seals too while I was there.
GM quality and will work with the HotCam and 1.6 Roller Rockers.
Inexpensive.
It will allow you a couple hundred more RPM before the valves will start floating.
