Funny noise when shifting under hard acceleration... Backfire????
My 92 (auto) makes a loud "thud", kinda"pop" noise when it shifts under hard acceleration.. Sounds like it could be exhaust backfire, but the engine runs great, no noticable loss of perfomance when this occurs... It is worse when the ASR is on.. Any Ideas??? Its is driving me nuts :crazy: .. I have done some work on the rear end, which did not change this problem, worse or better.. I installed poly bushings, outer tie rod ends, and new wheel bearings. Thanks in advance for any help... :cheers: :flag
Re: Funny noise when shifting under hard acceleration... Backfire???? (thmupr)
Yes i have the same problem. Gm has a "Technical Service Bulletin" for the 92 year corvette concerning this. I still haven't had the problem fixed so i can't hlp you much more. I didn't really realize that its was a backfire until i pulled the mufflers off and heard it pop.
It's a backfire and there is a TSB on it... The TSB describe the Opti as the culprit... i'm changing my opti to a brand spanking new oem unit... i'll let you know how it turns out..
My 92 has the same sort of condition, but I just attributed it to the fuel cut-off at 5800RPM and that seems to be just where the 1-2 shift occurs on mine. While I haven't notice this condition getting worse, it is there.
Have you tried to adjust the TV cable to see if that may be a solution? If somebody can post the TSB, it would be a big help!
UPDATE :D
Just checked the Alldata website where I found some info: http://www.alldata.com/TSB/10/92100604.html Scroll down the page where you begin to see dates in 1992. In Dec 92, there was a TSB issued for "Backfire during WOT 1-2 Upshift" The TSB is number 923366E and the listing shows the problem appears to be PROM related. The ALLDATA website only provides titles and TSB numbers and dates so you either have to buy a subscription or get the data from another source.
If you go to http://www.alldata.com and select the Technical Service Bulletins tab, you can specify year, make and model to see a listing of TSB's. Going to the Corvette page, there is a separate page for ZR-1's.
Thanks for the input guys! :cheers: It is indeed a TSB.. and it states that the prom is in need of replacement. The TSB does not say much other than that. I'll let ya know if it fixes it!! :flag :chevy
Re: Funny noise when shifting under hard acceleration... Backfire???? (oldace84)
The only code I have had in a while was code 32.. Here is a little background on the engine--- Opti, plugs, wires, and TPS replaced within the last 8 months. New Delco OPTI unit.. Doesn't use oil, 90+ Octane all the time,,, Borla Mufflers, and the "Tri-Claw" SLP intake.. Runs great other than that noise.. I did order the new prom for it that GM thinks will fix this problem.. Only $48 shipped from GM Parts Direct.... :cheers: :flag
