Windshield washer
Old Sep 24, 2003 | 12:18 PM
86shark's Avatar
86shark
Default Windshield washer
My windshield washer is not working, the wipers go on but they won't squirt. Washer fluid is full. anyone have problems with this in the past? Any info welcomed.
Old Sep 24, 2003 | 12:44 PM
QuikZilver's Avatar
QuikZilver
Default Re: Windshield washer (86shark)
Sounds like the washer pump may be shot. Haven't had this go on my Vette, did on my Rustang. Don't know how hard it is to replace on the Vette. My Rustang took about 10 minutes to replace.
:smash:
Old Sep 24, 2003 | 12:54 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: Windshield washer (Whitvette)
Can't say for the 86, but on the 91, the pump is on the bottom of the washer tank covered by a rubber boot. I had to remove the PS inner fender and gill plate to get enough room to pull the tank and pump. Might be the pump or connections.
[Modified by Steel Blue 91, 12:55 PM 9/24/2003]
Old Sep 24, 2003 | 01:26 PM
86shark's Avatar
86shark
Default Re: Windshield washer (Steel Blue 91)
I gotta change my sig :mad , the car is a 94, sorry about that. I will be looking at it tonight to see if I am getting power and that the hoses are connected. Thanks for the responses.
Old Sep 24, 2003 | 02:14 PM
Steel Blue 91
Being it is a 94, the pump should (operative word here) be in the same location. Pop the hood and have some one activate the washer while you listen.
Old Sep 24, 2003 | 06:25 PM
87vette's Avatar
87vette
Mine did the same thing. The hoses were fine.. no clogs.. I also got a new washer fluid pump as well. The damn thing still aint squirtin. WTF gives ?? !!! :mad
Old Sep 25, 2003 | 01:28 PM
SunCr's Avatar
SunCr
Default Re: Windshield washer (87vette)
Check for 12 volts at the pump while someone holds the switch (pink or anything other than black). If good, check ground. Otherwise it's in the switch or the module. If I'm reading the schematic correctly, Terminal F, brown wire at the switch to the module should have battery voltage with the switch depressed. If not, contacts in the switch are probably shot and it needs to be replaced.
To Windshield washer
