L98 mods
w/ the 160* thermostat, you'll want to turn your fans on sooner either with a custom computer chip or a fan switch available through some forum vendors (try MAD, ZIP, etc)
you can cut a large(r) hole in the stock air box
also, there is a large metal disk attached to the water pump pully. supposedly GM put it there to dampen vibrations caused by the ac compressor cycling on and off. remove the belt, and the four bolts holding the "frisbee" on the pully. Use washers on the bolts to to take up the thickness of the removed frisbee.
I agree with all your other descisions, except choice in spark plugs. Regular plugs work just as well, but open up the gap a bit with the new coil and wires.
your next mod should be long tube headers and dual exhaust. what you choose here will depend on local laws and $$. I'm using hedman 1 5/8" headers and a muffler shop bent 3" dual exhaust w/ h-pipe and no cats. I would choose at least 2.5" pipes, but would consider 3" with a superram and cam upgrade. Also, if I were to do it over, I would have saved a little more and gone with the Hooker Supercomp 1 3/4" headers.
Mods add up. :-)
Take care and enjoy your Vette!
Ron
The thermostat allows you to bump base timing, which can give some. The chip gives almost none.
You should remove the frisbee on the water pump (its a big round weight that serves no purpose) and that'll free up about 10hp.
If you want HP on the L98, youve got to change out the stock exhaust and do intake mods.
A 91 already has good heads, so those need nothing at this point.
What you should do since you cant afford the SR, is to port the plenum runners and base, port matching all the way and siamesing the runners.
Headers (longtubes) give about 15hp, catback about 10hp.
Its worth it. Accel has different vendors, but your best cheap bet is Ebay, all the vendors have nearly the same price.
For now just port the stockers.
Also, and this has been a long time debate, you can gut your MAF sensor (remove the screens and fins). Free mod, a little more airflow when you add the hi-flow intake parts.
As far as your air intake is concerned, just get a dremel, hacksaw, or tin snips and cut out the front of your air filter lid, so that there is just enough on the lip to hold the filter firmly in place. It's free, and with a K&N filter, should flow just as much as any aftermarket air intake kit.
Good luck! :thumbs:
[Modified by NavyVet, 9:58 AM 9/25/2003]
As for the chip, I installed a Hypertech Thermomaster in my 87 Coupe (auto tranny) and for me it works just fine. It just does not only start you fans earlier (you can do that with a manual switch for about $20) but it modifies your ignition timing and injector pulses. I did notice an increase in performance although I have read in this and other forums that they are worthless. Granted, a custom chip is supposed to be better since it is calibrated to your specific engine mods, but of course, it is more expensive I am told. Anyway, good luck with your mods, I expect to hear that you can smoke your Impala.
[Modified by alfonso gomez, 7:34 PM 9/25/2003]
For simple starters try these mods:
-160 deg stat & aux fan switch, 10hp
-toss the "frisbee",(details on my site, see sig. below), 10hp
-cut lid with K&N, 10hp; TPIS cold air, maybe 15hp over stock
-cut-back spark plugs (see my site), 10hp; you might also go with HyperTech coil, cap & rotor and TPIS wires to assure good firing to well over 5k RPM.
-AFPR to add fuel at WOT; don't do a chip change yet.
-bump the base timing till just below knock retard for better throttle response; you may need a scan tool for this trim.
Next do some exhaust work:
-headers, 15hp; or 2 1/2" mandrel bent front Y for about 5hp gain
-hi-flow cat & cat-back, maybe 15-20hp
Heads:
-pocket ported & worked #113s, 25hp
Cam:
-ZZ-9, 30hp
Check out the results of L98 mods on my site for the big picture on what you might expect from your L98 with a little work & $$ spent.
I think you'll find that your modded 12sec. Vette will run with your SS.
chip, 0 (A chip doesn't make power only an engine in tune)
106 T-stat, 3-5
hotter coil, 3-8
8mm wires 0-1
and platinum 4 plugs, 0
airfoil. 3-5
All combined 5-20 HP/TQ
Also wondering what brand of cold air intake is the best and most popular? This is tricky since you have to answer what risk I am willing to run? Many of the intakes will open towards the elements and are called "racing" because the stock will handle a water puddle, most will not.
Once you get rid of the TPI base restriction, you will be happy. But until then just keep up with the regular maintenance.
[Modified by dgoodhue, 8:11 AM 9/26/2003]
Good luck,
Ron
