C4 idle question
Old Sep 26, 2003 | 04:31 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: C4 idle question (Skruball73)
87 Normal 500-550, cold startup 900
Old Sep 26, 2003 | 04:51 PM
Mike263's Avatar
Mike263
Default Re: C4 idle question (dbwade36)
Mine (when TB is fully clean), idles @ 600 RPM at idle at a light. It sometimes jumps back @ forth from 500-600. That is, if the car is fully warmed up.
Sounds just like my 86.
Old Sep 26, 2003 | 07:55 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: C4 idle question (vinnies87)
Same for my '88 auto.
Old Sep 27, 2003 | 03:33 AM
black_89_vette's Avatar
black_89_vette
Default Re: C4 idle question (Tworacy)
Lately, it seems to be a bit rough though which is something I've been wondering about. Only mods are straight pipes after the cats.
Same thing happened to me, it started getting a little jumpy at idle. What I did was disconnect the battery for like 10 minutes, reconnect and start and let it idle by itself without touching the pedal at all for 15 minutes. I turned it off, let it sit for 10 minutes, and restarted it and let it run for 10 minutes.
Now, I don't know if that was the proper procedure or not, or even if the times were way off, but I will tell you this...my idle is rock solid now, no jumps or nothing. It definitely helped my idle doing that little procedure.
Old Sep 27, 2003 | 04:29 AM
MtlSphere's Avatar
MtlSphere
Default Re: C4 idle question (85 Dave)
My 85 idles 550-600.
Ditto :seeya
Old Sep 29, 2003 | 01:32 AM
drvette85's Avatar
drvette85
Same here. :seeya
Old Sep 29, 2003 | 09:18 AM
Saisling's Avatar
Saisling
St. Jude Donor '05
Default Re: C4 idle question (drvette85)
Quote:
My 84 idles at 1800-2000 when cold, then drops to 12-14, then when fully warm 700-800.
:eek:
Mine idles at 900 when it's cold and then usually 700-800 once it warms up. (Thats out of gear.) In gear, it idles around 500-600
